I want to use command notify-send and display text from a file as a notification so that I can only edit that file to change command or forward contents from outputs of other programs to notify-send.
I tried :
  • notify-send -u critical -t 3000 < ~/ved
  • cat ved | notify-send -u critical -t 3000
It says : No summary specified.
What should I do about this summary?
VedVals
  • 3,651
http://www.commandlinefu.com/commands/view/4460/pipe-output-to-notify-send
says
echo 'information overlord' | while read OUTPUT; do notify-send "$OUTPUT"; done
10
Im not sure what you want to do or what kind of file you want to display but man notify-send says
notify-send [OPTIONS] <summary> [body]
Summary being a title, so for example, the basename of your file.
So what you can do is
notify-send -u critical -t 3000 "$(basename ~/ved)" "$(cat ~/ved)"
But be aware that notify-send won't print long text file, it's not its job.
Also, I don't know for you or everyone else, but the -t option never worked for me, time being always 10s. I've read it was a bug a long time ago and it's still not working in 12.04.
VedVals
  • 3,651
user55822
  • 3,245
Try this:
notify-send -u critical -t 3000 "$(cat ~/ved)"
