I accidently installed Ubuntu 12.10 using the option "LVM" although i've not selected erase disk and fresh install. Now my systems boots direclt into Ubuntu and I'm unable to see my Windows files on hard drive so I'm unable to access my old data (documents, movies, music, pictures) stored on Windows? Can someone help me to bring back my old Windows?
In fact, I've now completely erased my hard drive yesterday and its only ubuntu 12.10 running on my laptop and i surely want to install my paid windows 7 home premium back as a dual booting system. But I also like to first try uninstall or revert my ubuntu installations and get back my windows so that i'll able to at least retrieve my previous data and than perform this new task.
jobukkit
  • 5,266
M. Junaid
Easiest way would be to try the Recovery disk for windows 7. It has repair option to repair the boot management. It should automatically detect your windows and fix its Boot issue. ( you will loose Ubuntu boot option with it)
Second option is to Prepare a USB stick with Ubuntu in it. Re-install the whole thing from Scratch and leave windows 7 partition as it is.
It will give you both Ubuntu and Windows 7. :)
Vikash Singh
  • 2,383
-1
Then why did you erase your hard-drive?! If you erase your hard-drive, your data is gone! That's too obvious!
Also, why don't you have a backup?!
Stop using your computer NOW. You might be able to rescue your data!
Every time you write data to your hard-drive, the chance of possibility you might be able to rescue your data lowers! So stop using your computer NOW!
Create an Ubuntu Rescue Remix disk, boot from it and rescue your data using these instructions: https://help.ubuntu.com/community/DataRecovery#Lost_Partition
Also, you don't have to delete Ubuntu in order to use Windows. You can have Windows alongside Ubuntu. The installer asked that.
jobukkit
  • 5,266
