I recently purchased the WNA1100 WiFi Adapter for my Ubuntu Server 12.04 Box. Since I'm new to Ubuntu, I'm unable to install the drivers for the WiFi Adapter. I found that the WiFi adapter uses the Atheros AR9271 chipset. I downloaded the htc_9271.fw file from the Linux Wireless site.
How do I install the driver?
Faheem Mitha
  • 7,871
Srijit
  • 31
6 Answers6
You may need both files there; htc_9271.fw and htc_7010.fw. Both are mentioned in:
    modinfo ath9k_htc
Please open at terminal and do:
    cd Desktop   <--or wherever the downloaded files are
    sudo cp htc_9271.fw /lib/firmware
    sudo cp htc_7010.fw /lib/firmware
Now unload and reload the driver:
    sudo modprobe -r ath9k_htc && sudo modprobe ath9k_htc
chili555
  • 61,330
I recommend you return the card and purchase something that's already supported:
https://help.ubuntu.com/community/WifiDocs/WirelessCardsSupported
You are probably used to wrestling with driver annoyances in Windows and therefore think it's pretty normal. In Linux, it isn't. If you have to wrestle with drivers, it's because your card isn't actually supported - you may be able to get it to work, but you're usually better off just returning it and getting something that IS supported, which will "just work" without needing to fight with it.
Jim Salter
  • 4,383
Just unplug and plug back your usb adapter.
This worked for me after reconnecting the device!
Eliah Kagan
  • 119,640
chris
This was not working for me and I was banging my head against wall. Until I run apt-get update && apt-get upgrade.
The recent upgrade solved the issue, and the card is working with charm.
Ubuntu: 13.04 Kernel: 3.8.0-30-generic #44-Ubuntu
Bonjour à Toutes et à Tous.
Merci pour les efforts, l'altruisme et la sympathie avec laquelle vous apportez de l'aide aux besogneux de la communauté UBUNTU.
Mon problème était le suivant : ma Clé USB Netgear WNA1100 N150 Wifi ne fonctionnait pas sur UBUNTU 16.04 LTS.
Solution :
1 - j'ai téléchargé ath9k_htc-installer_1-0-4.deb
2 - Dans le dossier Télécharger, clique droit sur le nom du paquet, puis Ouvrir avec installation de l'application.
Resultat : ça marche.
Encore merci.
-1
@Jim Salter If you check the site you gave you will find that Netgear WNA 1100 is supported:
"WNA1100
Atheros
ath9k_htc
Need only a .deb packet
Download the last version of the http://sourceforge.net/projects/ath9...htc-installer/ and execute the .deb packet. Connect the WiFi adapter"
