how can I install Ubuntu 12.10 to an external USB HDD?
On the disc partitioning screen of the installer there is only /dev/sda showing up in the list. However in a terminal window I can see /dev/sdb with sudo fdisk -l. So how can I get ubiquiti to show /dev/sdb as well?
Ringtail
  • 16,285
medve
  • 143
It sounds like the USB drive is not mounted.
Try unplugging it and plugging it back in, or use Disc Utility to check it is mounted.
EDIT :
From the picture it looks like the USB drive has the wrong mount point as /cdrom.
It should be automatically mounted at /media/name-of-drive.
This is why the installer does not see it.
Have a look at comment #6 in this old bug report and see if it helps.
Solution
The simple solution is not to connect the USB HDD until after the live 12.10 CD boots up completely.
You did click on the dropdown box in the top right, right ?
See this for the dropdown box with /dev/sda selected.
user55822
  • 3,245
