I'm using ubuntu i686.
Need to install i386 .rpm packages.
tried this code:
alien -i [file.i386.rpm]
Tried to install ia32-libs...
apt-get install ia32-libs
...and tried alien again but didn't work.
any suggestion? thx.
[EDIT]
[suggestion #1: run alien with sudo -c -v ...]
your suggestion didn't work. Same error reported:
file.i386.rpm is for architecture i386 ; the package cannot be built on this system.
The line above the error is the command chmod:
chmod 755 ["name of directory"/debian/rules]
any other suggestion? thx.
Raffaello
  • 151
5 Answers5
As found on https://www.maketecheasier.com/convert-32bit-rpm-to-deb-64bit/, this is a nice easy workaround - after converting to TGZ as an intermediate stage, just convert again to the .deb:
sudo alien --scripts --to-tgz <package.rpm>
sudo alien --scripts --to-deb <package.tgz>
The --to-deb is a default, used here only to be explicit about the conversions.
Randall
  • 356
I had the same problem and solved it this way:
alien --to-tgz --scripts file.i386.rpm
mkdir unpack
cd unpack
tar -xpzf ../file.tgz
mv install ..
cp -rv * /
cd ../install
./doinst.sh
The RPM is converted to a TGZ file. Be aware that the ".386" is not in the name of the TGZ file.
The current answers say to convert to .tgz, but that did not work for me as it was leaving out necessary metadata during this two-step conversion process. I wanted to directly convert some RPMs to deb files with alien.
First step was to see how alien was detecting my system architecture, then I could find a way to disable it. With a bit of help from dpkg -L alien and grep, I located the code responsible for this error. It starts on line 552 of /usr/share/perl5/Alien/Package/Deb.pm.
# Detect architecture mismatch and abort with a comprehensible
# error message.
my $arch=$this->arch;
if ($arch ne 'all') {
    my $ret=system("dpkg-architecture", "-i".$arch);
    if ($ret != 0) {
        die $this->filename." is for architecture ".$this->arch." ; the package cannot be built on this system"."\n";
Just add --target=all to your command.
alien --target=all -i file.i386.rpm
Botspot
  • 101
Run alien with sudo and -c -v parameters:
sudo alien -i -c -v file.i386.rpm
The -c (--scripts) parameter Include scripts in package
The -v (--verbose) parameter Display each command alien runs so you can see what is going wrong.
ptheo
  • 1,686
-2
8086 = 8-bit
80186 = 8-bit
80286 = 16-bit
80386 = 32-bit
80486 = 32-bit
80586 = 32-bit = Pentium, Pentium MMX, K5, K6, K6-II, K6-III
80686 = 32-bit = Pentium Pro, Pentium II, Pentium III, Athlon, Athlon XP, Opteron*, Athlon FX-51*, Athlon FX-53*, Athlon 64*
80786 = 32-bit = Pentium 4
  • = 32-bit/64-bit
If you have compiled a program for 386 architectures, only the processors equal to it or above it can execute it.
So the i386.rpm cannot run to your ubuntu i686
ptheo
  • 1,686
