For Virtual Machines I create, as well as on old computers I use, I'd like to turn off gdm/lightdm in order to get better performance. I don't like to boot into single user mode ("linux single") because using root is a bad practice, and I also prefer to keep an easy way to boot back into graphic mode, so when graphic mode is required, no extra commands would be needed.
The way I see as the most useful is to configure Grub to show a menu item for "Ubuntu Text mode" in addition to the regular boot and the recovery mode, and set the text mode as default. I tried to do it myself, but Grub2 configuration files on /etc/grub.d/ looks too cryptic to me, and /etc/defaults/grub can set booting into text but it doesn't seems to allow keeping a menu item for graphical booting as well as setting text or graphics as default, and I prefer to keep the booting process simple to novice users so they won't need to mess with starting services manually or editing the kernel boot command line in Grub2.
Similar threads: https://askubuntu.com/a/196613/19967, https://askubuntu.com/a/79682/19967 - completely remove GUI and start it from the command line instead of Grub2 menuitems.
