Are there any differences between installing Apache httpd using sudo apt-get install apache2 (as the guide of Ubuntu says - https://help.ubuntu.com/12.04/serverguide/httpd.html ) or following the steps on the Apache documentation (http://httpd.apache.org/docs/2.4/install.html#overview)?
I tried both ways; in the first case (using apt-get) the server seems to work - I open a browser page and I got it. In the second case I need other packages (apr, apr-util and pcre) and so I abandoned the attempt.
It is because when you use apt-get (default package manager for Ubuntu), it automatically installs the dependencies. But when installing manually (using ./configure, make and make install), you'll have to make sure that the dependencies are already installed for the program to work. Otherwise, you'll have to manually install the required dependencies as well.
You can refer the answer to this question for further details:
Installing suggested/recommended packages?
Vishal
  • 156
