Hello I am new to ubuntu. I am trying to install Apache2 using "sudo apt-get install apache2" command.I have set my java path as per rules but still its showing me this following errors:
sha256sum mismatch jdk-7u3-linux-i586.tar.gz
Oracle JDK 7 is NOT installed.
dpkg: error processing oracle-java7-installer (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of libcommons-dbcp-java:
libcommons-dbcp-java depends on default-jre-headless | java2-runtime-headless; however:
Package default-jre-headless is not installed.
Package oracle-java7-installer which provides default-jre-headless is not configured yet.
Package java2-runtime-headless is not installed.
Package oracle-java7-installer which provides java2-runtime-headless is not configured yet.
dpkg: error processing libcommons-dbcp-java (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libtomcat6-java:
libtomcat6-java depends on libcommons-dbcp-java; however:
Package libcommons-dbcp-java is not configured yet.
dpkg: error processing libtomcat6-java (--configure):
dpkg: dependency problems prevent configuration of tomcat6-common:
tomcat6-common depends on libtomcat6-java (>= 6.0.32-5ubuntu1.2); however:
Package libtomcat6-java is not conNo apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
figured yet.
dpkg: error processing tomcat6-common (--configure):
dpkg: dependency problems prevent configuration of tomcat6:
tomcat6 depends on tomcat6-common (>= 6.0.32-5ubuntu1.2); however:
Package tomcat6-common is not configured yet.
dpkg: error processing tomcat6 (--configure):
dpkg: dependency problems prevent configuration of tomcat6-admin:
tomcat6-admin depends on tomcat6-common (>= 6.0.32-5ubuntu1.2); however:
dpkg: error processing tomcat6-admin (--configure):
dpkg: dependency problems prevent configuration of tomcat6-docs:
tomcat6-docs depends on tomcat6-common (>= 6.0.32-5ubuntu1.2); however:
dpkg: error processing tomcat6-docs (--configure):
dpkg: dependency problems prevent configuration of tomcat6-examples:
tomcat6-examples depends on tomcat6-common (>= 6.0.32-5ubuntu1.2); however:
dpkg: error processing tomcat6-examples (--configure):
dpkg: dependency problems prevent configuration of tomcat6-user:
tomcat6-user depends on tomcat6-common (>= 6.0.32-5ubuntu1.2); however:
dpkg: error processing tomcat6-user (--configure):
libtomcat6-java
tomcat6-common
tomcat6
tomcat6-admin
tomcat6-docs
tomcat6-examples
tomcat6-user
root@sheetal:/home/prakash/Downloads#
