In Ubuntu 12.04 and previous versions, I can easily install smbfs and running smb://server/share from Nautilus works!
But, in 12.10, I can't install smbfs. Trying to install it from the terminal, I see this that the package is obsolete:
Reading package lists... Done
Building dependency tree
Package smbfs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  cifs-utils
E: Package 'smbfs' has no installation candidate
How can access my Windows share easily in 12.10?
Peachy
  • 7,235
  • 40
  • 47
Cyberscooty
  • 111
As far as I know it's replaced with cifs-utils now
sudo apt-get install cifs-utils
There's also this nice and somewhat related article about mounting windows shares.
BuZZ-dEE
  • 14,533
rmq
  • 41
If file is shared it will show under network folder. Samba client is installed by default.
Arup Roy Chowdhury
  • 1,580
Maybe you can use Smb4K or for command line smbclient. Both can be installed through Ubuntu Software Center.
