so i have upgraded to Ubuntu 12.10 and i installed smplayer from the repositories. The thing is when i play a movie (even in full screen) the screen saver comes up. I have to disable screensaver enabled in smplayer but it doesn't seem to work
apt-cache policy mplayer
mplayer:
  Installed: 2:1.0~rc4.dfsg1+svn34540-1ubuntu2
  Candidate: 2:1.0~rc4.dfsg1+svn34540-1ubuntu2
  Version table:
 *** 2:1.0~rc4.dfsg1+svn34540-1ubuntu2 0
        500 http://pt.archive.ubuntu.com/ubuntu/ quantal/universe amd64 Packages
        100 /var/lib/dpkg/status
apt-cache policy gnome-screensaver
gnome-screensaver:
  Installed: 3.6.0-0ubuntu2
  Candidate: 3.6.0-0ubuntu2
  Version table:
 *** 3.6.0-0ubuntu2 0
        500 http://pt.archive.ubuntu.com/ubuntu/ quantal-updates/main amd64 Packages
     3.6.0-0ubuntu1 0
        500 http://pt.archive.ubuntu.com/ubuntu/ quantal/main amd64 Packages
Any ideas?
psychok7
  • 523
The -p option doesn't exist anymore.
Its a bug in gnome-screensaver. http://lists.mplayerhq.hu/pipermail/mplayer-users/2012-November/085566.html
first install xdotool Then add to mplayer config or comand line
heartbeat-cmd="xdotool key shift"
This will send shift key press and release as code above but using xdotool.
AkhIL
  • 31
I am not sure whether smplayer reads ~.mplayer/config, but you need to
sudo apt-get install libxtst-dev
(maybe more, I had some developement packages already installed)
paste this into a file called sendXshift.c
/* program to send shift-down, shift-up through X test extension to indicate that the X session isn't idle */
#include <stdio.h>
#include <stdlib.h>
#include <X11/Xlib.h>
#include <X11/extensions/Xext.h>
#include <X11/extensions/XTest.h>
int main(){
  Display *dpy;
  Status stat;
  int i1,i2,i3,i4;
  Bool stat1;`
  dpy = XOpenDisplay(NULL);
  if (dpy == NULL){
    printf("open display failed\n");
    exit(1);
  stat1 = XTestQueryExtension(dpy,&i1,&i2,&i3,&i4);
  if (stat1 == 0){
printf("Xtest not supported\n");
XCloseDisplay(dpy);
exit(1);
  // shift down:
  XTestFakeKeyEvent(dpy,0x32,True,CurrentTime);
  // shift up:
  XTestFakeKeyEvent(dpy,0x32,False,CurrentTime);
  XCloseDisplay(dpy);
And compile with cc -o sendXshift sendXshift.c -lX11 -lXtst, make it executable and then put heartbeat-cmd="/PATH/TO/COMPILED/FILE/sendXshift".
This should do until/if http://bugzilla.mplayerhq.hu/show_bug.cgi?id=1887 isi solved.
sup
  • 4,964
My guess is this: gnome-screensaver removed the "poke" argument.
Mplayer however tries to poke the screensaver via
heartbeat-cmd="gnome-screensaver-command -p"
and fails.
I'm not sure how to proceed, setting the hearbeat command to
heartbeat-cmd="gnome-screensaver-command --exit"
would disable the screensaver for the whole session.
It may be best to install xscreensaver instead. Or use DBUS to inhibit the screensaver. For gnome-shell there are extensions to pause the screensaver manually.
ko-dos
  • 6,288
  • 14
