87
I just ran a clean install of 12.10 on my sys76 laptop.
Time and date reads: 19:36 31 december 1969, even though it is: 13:29 07 november 2012.
I have it set for my location and it won't change manually, even tried in the command line with tz.
I think it is messing up the security certificates over the Internet cause I cannot change PPA over command line and going to Launchpad brings up the certificates page in Firefox.
Is this some known bug or is there a fix for it?
dysonsphere
  • 871
8 Answers8
92
Try:
sudo ntpdate ntp.ubuntu.com
Yes, it would certainly mess with the SSL certificates, because they would be future-dated.
I doubt it's a bug in Ubuntu. Your CMOS clock in the BIOS must have been set to that somehow.
Will Daniels
  • 1,746
41
Just install ntp server:
sudo apt-get install ntp
It will automatically keep your clock synchronized.
Eric Carvalho
  • 55,453
26
Install ntp and ntpdate executing the following commands-
sudo apt-get install ntpdate
Then, execute
This works for me.
find your timezone:
timedatectl list-timezones
and then set your timezone based on your choice:
timedatectl set-timezone <YOUR_TIME_ZONE>
Sina
  • 231
After installing 12.10 I had the same problem as well. Somehow the new installation set the BIOS clock to the year 2070 !! After this, Ubuntu wasn't able to set a different date both by ntp, manually, even using the date command.
Setting the right date in the BIOS settings solved the problem.
aizquier
  • 186
This works for Ubuntu 16.04
  1. Stop the ntp service
  2. Run ntpdate command to fetch date/time from ntp.ubuntu.com
    systemctl stop ntp
    sudo ntpdate -s ntp.ubuntu.com
P.S: Make sure ntp is installed, if not just do
shylynx
  • 2,411
I changed the hardware clock. Use the hwclock command to fix it:
sudo ntpdate <my.ntp.server>
sudo hwclock -w
renedet
  • 121
Install this package to get the clock of your server right:
sudo apt install aptitude
sudo aptitude install ntp
Then define your time zone (the one where your server is located):
sudo dpkg-reconfigure tzdata
Details:
https://safaetulahasan.medium.com/set-time-of-your-server-right-7145899166a4
