Possible Duplicate:
Share between Ubuntu machines
I have a MacPro desktop and a Dell laptop. I want to connect them such that file sharing is as fast as possible. Possibly I'd like to see the hard-drives of each machine mounted making the copying process seamless:
Copying from MacPro to Dell:
cp /mnt/macpro/home/foo /home/path-to-somewhere
Copying from Dell to MacPro:
cp /mnt/dell/home/foo /home/path-to-somewhere
Any suggestion?
In practice I have a lot of data (therabytes) and I want to exploit all the cpu-cores I have to process them.
memecs
  • 281
over the network :
You can use file sharing software like NitroShare
or else you can use default public sharing:
http://www.howtogeek.com/116309/use-ubuntus-public-folder-to-easily-share-files-between-computers/
or else Ultracopier is software you can use to copy locally from drive to drive
Fabby
  • 35,017
swapyonubuntu
  • 1,002
As pointed out, this question provides the answer: Share between Ubuntu machines
Use method 2 described there. To find out the IP adress of one machine (so it can be entered on the other), open a terminal and run this command:
ifconfig
Also, an abundance of CPU cores won't do you any good. The bottleneck here is the network.
Kalle Elmér
  • 9,216
