I have the HVR-2250, the system does see it, card 3,but I can't figure out how to get it going to watch TV. I have My TV and Kaffine. Any body have a step by step by step? It works great in Windows 7 64 bit with WMC. I would like to switch over to Linux and have some of the same abilities.
Thanks
user106232
I just picked up 2 of these cards for my linux box and ran into the same issue. however all is not lost. ~Pending on what version of Ubuntu you are running ( I am running 12.10 studio version) the command is quite easy and should work with any *buntu distro 8.10 and up.
Download the firmware file from this link: http://www.steventoth.net/linux/hvr22xx/firmwares/4019072/NXP7164-2010-03-10.1.fw
after you download that folder change to the directory that your download is in (/home/
Copy the firmware file to the firmware directory
sudo cp NXP7164-2010-03-10.1.fw /lib/firmware
then, reload the saa7164 module:
sudo rmmod saa7164
sudo modprobe saa7164
Thanks to DigitalRazor's answer I was able to setup my wintv-hvr-2250 under Ubuntu 12.04.1 (64bit). The link in his answer has a typo. Here is the correct link.
The sha1sum for the file is 6d23a53acb339a0cc229312306c05d03c0770f9a
I've also uploaded a copy here.
I intended to use VLC at first but it requires more manual setup. Kaffeine is much easier to use.
Seth
  • 59,332
