19
I have dual booted windows 7 and Ubuntu 12.04 LTS and have decided that I need more space on my Ubuntu partition. I used gparted on a Live CD to shrink my Windows 7 partition (/dev/sda3) but when i try to resize the extended partition (/dev/sda4), which houses my linux partition (/dev/sda6), the right click options are greyed out and there is a key next to the extended partition.
I have resized the partitions within the extended partition before to provide room, but now I can go no further with that, and need to grow the extended partition. The free space lies to the left of the extended partition and there is a small amount of free space directly to the right as well.
Also, within the extended partition is /dev/sda5 (ntfs) , which I have no idea what is on it, but most of the space (3.42GB) is used, /dev/sda6 (ext4, mount point: /), my partition containing Linux, and /dev/sda7 (linux-swap). I hope you guys can help me with this because I really don't want to screw something up while trying to resize the extended partition.
Kyle Macey
  • 1,679
It is likely that the extended partition is locked because your LiveCD environment is swapping to the swap partition which is inside of the extended partition.
Right-click on the swap partition and select "Swap off"
Sergey
  • 44,353
