First I want to clarify that I know how to format an SD card with programs like KDE Partition Manager or GParted.
What I am really looking for is an easy way to do that, such as right-clicking in Dolphin on my SD Card or USB pendrive and selecting format drive.
I think I just can't figure out an easy way. Think about a way you would tell a non-sudo user how to format his SD card.
In Cinnamon, the USB pendrive can be right-clicked and formatted directly from the file manager (Nemo). Is something similar available in Dolphin?
Thomas
  • 183
I wasn't able to find a one-click solution for what you want, but I think that the USB Formatter [mintstick] service menu for Dolphin might be close to it.
  1. To add the service menu to Dolphin's right-click menu you first have to install mintstick. Download and install its latest version (1.4.4) in your Downloads directory using the following command:
    wget -O ~/Downloads/mintstick_1.4.4_all.deb http://packages.linuxmint.com/pool/main/m/mintstick/mintstick_1.4.4_all.deb
  2. Install it using:
    sudo apt install ~/Downloads/mintstick_1.4.4_all.deb
  3. Download the USB Formatter [mintstick] .desktop file from here.
  4. Supposing that you have saved the file in your Downloads directory, copy the file in ~/.local/share/kservices5/ServiceMenus using:
    mkdir -p ~/.local/share/kservices5/ServiceMenus/ && cp ~/Downloads/FormatUSB.desktop ~/.local/share/kservices5/ServiceMenus/
    The above command will also create the required folders if they do not exist.
  5. You should now be able to find the option to format a USB with mintstick (USB Stick Formatter) by right-clicking in a directory → ActionsFormat USB.
This service menu also adds an option to also have the Format USB option in the device notifier, but as the author of the service menu notes:
Note: in order to display the "Format USB" option in the removable device notifier, you must have pressed the "format usb" button in the dolphin menu at least one time.
Also have a look at the related video to see how the service works.
Note: I haven't tested the above, since I don't currently have an installation with KDE. Any feedback is appreciated.
