11
I recently replaced the indicators in the gnome panel with the Indicator Applet Complete, as can be seen in the screenshot below.
alt text
However I really miss the weather which used to be displayed with the date gnome applet. I tried searching for an alternative weather indicator and found one here. However its ppa is empty and no longer works.
Is there any other alternative? I prefer it being an indicator rather than a ordinary gnome applet as I already know that there is one that can be added to the gnome panel (screenshot below for more info)
alt text
Jorge Castro
  • 73,717
nik90
  • 12,959
There is
indicator-weather Install indicator-weather
After installing, you can start the indicator by running indicator-weather. Keep an eye on their project page for updates!
To make the indicator start automatically:
  • Go to System → Preferences → Startup Applications (Or Applications → Startup Applications if you're on Unity)
  • Click Add and select indicator-weather as the command.
To quit it, run killall indicator-weather in a Terminal. (Check if it doesn't start automatically after installing from the PPA below, I'm not sure)
