11
So I have upgraded Ubuntu with the latest Kernel. But after the upgrade and after I rebooted Ubuntu, all I get is GRUB. How do I load Ubuntu again when all I have is GRUB?
I installed Ubuntu using wubi.
Thanks heaps for the help
Using Grub
If you get to a grub prompt and the system and kernel are still installed on the partition, you can "manually" boot the system - i.e. without the help of a working grub.cfg. This also works with a grub run from live media. To this end grub includes a rudimentary command ine, which you can use to find the partition and boot the system.
find /vmlinuz
This should give you the partition like (hd0,0). You can also use the ls command to poke around the partition and see which kernels are available. The search command works similarly. You can also use tab completion.
set root=(hd0,1)
Of course, replace the parition identifier with whatever find showed you.
linux /vmlinuz root=/dev/sda1
initrd /initrd.img
Select the kernel image and initrd image, a pair which always needs to be used together. Luckily Ubuntu creates a pair of symlinks in the root directory which point to a working image and initrd. Note that you need to replace /dev/sda1 with a representation of the partition in the scheme used by the Linux kernel. Roughly, (hd0,1) corresponds to /dev/sda1; (hd0,2) corresponds to/dev/sda2;(hd1,1) corresponds to /dev/sdb1.
boot
This boots the selected kernel from the selected partition. Once you've managed to boot your system, you can use that to restore grub, as is detailed e.g. here.
Grub with Wubi
The above was premised on the assumption that Ubuntu was installed regularly, i.e. in its own separate partition. As you write, you used Wubi, which means you installed it to a large file on a Windows (NTFS) partition using a technique called "Lupin". I see no reason why this couldn't work in principle, though the process is more complicated. Here's the content of a grub.cfg based on a Wubi install:
insmod part_msdos
insmod ntfs
set root='(hd0,msdos5)'
search --no-floppy --fs-uuid --set be300f9c300f5ab3
loopback loop0 /ubuntu/disks/root.disk
set root=(loop0)
linux /boot/vmlinuz root=/dev/sda1 loop=/ubuntu/disks/root.disk
initrd /boot/initrd.img
You'll need to adapt this to your particular case. In this snippet, taken from a 10.10 install, the search command finds the root partition using a filesystem UUID or identifier, which you presumably don't know; you can use --file --set /ubuntu/disks/root.disk instead (here's the official documentation). This grub configuration creates a virtual disk - a "loopback device" - called loop0 which represents the contents of the "partition file", /ubuntu/disks/root.disk on your NTFS partition. With a bit of trial and error, you should be able to make this work.
loevborg
  • 7,414
