I have Ubuntu 12.10 and whenever I run sudo modprobe ndiswrapper, I get the following error.
FATAL: Module ndiswrapper not found.
The command dkms status returns with...
ndiswrapper, 1.57, 3.2.0-32-generic, i686: installed
When I run ndiswrapper -v I am returned with this...
jason@jason:~$ ndiswrapper -v
utils version: '1.9', utils version needed by module: '1.9'
module details:
filename:       /lib/modules/3.5.0-18-generic/updates/dkms/ndiswrapper.ko
version:        1.58rc1
vermagic:       3.5.0-18-generic SMP mod_unload modversions 686
I have installed commons, utils-1.9, dkms, source but it's still returning this error. How do I fix this?
thank_you
  • 667
6 Answers6
Based on what you have installed, this may seem silly, but have you installed ndiswrapper-dkms? That should allow you to sudo modprobe ndiswrapper.
smskelley
  • 170
The main reason for this error is bug in ndiswrapper 1.57 version. Check out this.
Download ndiswrapper 1.58 rc build here with better code than 1.57. It will work. Good luck
KK Patel
  • 19,753
I had to run echo ndiswrapper >> /etc/modules
EDIT: Run this first:
sudo rm -f /lib/modules/3.5.0-*-generic/updates/dkms/ndiswrapper.ko
Then run this:
sudo apt-get install --reinstall ndiswrapper-dkms ndiswrapper-source
This will recompile the ndiswrapper so that it will work on your kernel. See if it works for you.
MiJyn
  • 3,396
That is not the right kernel version for 12.10 (check current running kernel with uname -r command). Try:
sudo dkms build -m ndiswrapper -v 1.57
sudo dkms install -m ndiswrapper -v 1.57
Let us know if that succeeds in forcing ndiswrapper to be rebuilt.
Will Daniels
  • 1,746
-1
You can either wait for a fix to the bug or follow steps outlined in the bug comments, something along these lines:
mkdir ~/src
cd ~/src
wget http://downloads.sourceforge.net/project/ndiswrapper/testing/ndiswrapper-1.58rc1.tar.gz
tar -xvf ndiswrapper-1.58rc1.tar.gz
cd ndiswrapper-1.58rc1
make
sudo make install
Will Daniels
  • 1,746
