I'm trying to create a bootable USB image to install Ubuntu on a new computer.
I have done this before following the "create USB drive" instructions for Ubuntu desktop, but I don't have an Ubuntu desktop available.
How can I do the same using only the command line?
Things I've tried:
- Create bootable USB on Mac OS X following the ubuntu.com "create USB drive" instructions for Mac: Doesn't boot.
usb-creator: According toapt-cache search usb-creatorand Wikipedia usb-creator only exists as a graphical tool.- "Create manually" instructions at help.ubuntu.com: None of the files and directories described (e.g.
casper,filesystem.manifest,menu.lst) exist in the ISO image, and I don't know what has replaced them. - unetbootin scripting: Requires X server (graphics support) to run, even when fully scripted. (The command
sudo unetbootin lang=en method=diskimage isofile=~/ubuntu-10.10-server-amd64.iso installtype=USB targetdrive=/dev/sdg1 autoinstall=yesgives an error messageunetbootin: cannot connect to X server.)
Update
Also tried GRUB fiddling: Merging information from
I was able to get halfway there - it booted from USB, displayed the grub menu and started the installation, but the installation did not complete.
For reference, this is the closest I got:
sudo su
# mount USB pen
mount /dev/sd[X]1 /media/usb
# install GRUB
grub-install --force --no-floppy --root-directory=/media/usb /dev/sd[X]
# copy ISO image to USB
cp ~/ubuntu-10.10-server-amd64.iso /media/usb
# mount ISO image, copy existing grub.cfg
mount ~/ubuntu-10.10-server-amd64.iso /media/iso/ -o loop
cp /media/iso/boot/grub/grub.cfg /media/usb/boot/grub/
I then edited /media/usb/boot/grub.cfg to add an .iso loopback, example grub entry:
menuentry "Install Ubuntu Server" {
set gfxpayload=keep
loopback loop /ubuntu-10.10-server-amd64.iso
linux (loop)/install/vmlinuz file=(loop)/preseed/ubuntu-server.seed iso-scan/filename=/ubuntu-10.10-server-amd64.iso quiet --
initrd (loop)/install/initrd.gz
When booting from USB, this would give me the Grub boot menu and start the installer, but the installer gave up after a couple of screens complaining that it couldn't find the CD-ROM drive. (Naturally, as the box I'm installing on doesn't have an optical drive.)
I resolved this particular issue by giving up and doing the "create USB drive" routine using the Ubuntu Live desktop CD (on a computer that does have an optical drive), then the USB install works.
But I expect that there is some way to do this from the command line of an Ubuntu system without X server and without an optical drive, so the question still stands.
Does anyone know how?
