Recently I have installed Code::Blocks IDE on my Ubuntu 12.10. The following error appears when I try to run or compile any code written in there:
Compiling: /home/sabbir/first.cpp
/bin/sh: 1: g++: not found
Process terminated with status 127 (0 minutes, 0 seconds)
0 errors, 0 warnings
How can I solve this problem?
sabbir
  • 223
Most likely you are simply missing a compiler.
Get one by installing build-essential package.
Typing sudo apt-get install build-essential into terminal is one of the easiest ways to achieve that.
i think you have to install g++ c++ compiler using synaptic package manager
There is no c++ compiler! You should install gcc c++
apt install gcc-c++
After installing c++ compiler it will work
