I am new to Ubuntu/Linux.
I have installed the Ubuntu 12.10 version on Windows 8. After installation, there is no wireless connectivity. I have searched the forums and tried things that have worked for others. But, every way seems to be a dead-end to me.
I ran the command lspci -nn | grep 0280 and here is the details I get.
03:00.0 Network controller [0280]: Broadcom Corporation BCM43228 802.11a/b/g/n [14e4:4359]
The command sudo iwconfig gives the below output.
eth0      no wireless extensions.
lo        no wireless extensions.
I downloaded the bcmwl-kernel-source from Ubuntu Software Center and installed, but there is no change.
I am at a loss, being new to the OS.
Any help from you will be much appreciated. Kindly let me know if I missed to provide any information.
jokerdino
  • 41,732
If you have several drivers installed, the Linux kernel will pick the right one automatically. Regardless of the driver, though, your chip might need firmware to work. Find firmware-b43-installer from the Software Center.
The STA driver, provided by bcmwl-kernel-source is correct for your device.
What is the result if you load the module? Are there warnings or errors?
    sudo modprobe wl
    dmesg | grep wl
chili555
  • 61,330
Install synaptic form the Ubuntu Software Center
In Synaptic select bcmwl-kernel-source and bcmwl-sta-source
Then install it.
I'm sorry you must have a connection internet try wired.
