I recently upgraded Ubuntu 12.04 to 12.10 only to find out that it won't connect to any network, neither wired nor wireless and the graphics is messed up too as in a low screen resolution.
For 12.04, my system was running perfectly. I don't know why upgrade messed it up so bad. Reinstalling the OS is an issue because I have set up a lot of development environments that I cannot afford to set it up again.
Some of the outputs:
lspci -nn | grep 0200:
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 02)
nm-tool:
NetworkManager Tool
State: disconnected
cat /etc/network/interfaces:
auto lo
iface lo inet loopback
sudo cat /var/log/syslog | grep etwork | tail -n20:
Nov  2 13:50:22 Cobalt NetworkManager[978]:    SCPlugin-Ifupdown: (-1240454760) ... get_connections (managed=false): return empty list.
Nov  2 13:50:22 Cobalt NetworkManager[978]:    Ifupdown: get unmanaged devices count: 0
Nov  2 13:50:22 Cobalt bluetoothd[1016]: Failed to init network plugin
Nov  2 13:50:22 Cobalt NetworkManager[978]: <info> modem-manager is now available
Nov  2 13:50:22 Cobalt NetworkManager[978]: <info> monitoring kernel firmware directory '/lib/firmware'.
Nov  2 13:50:22 Cobalt NetworkManager[978]: <info> WiFi enabled by radio killswitch; enabled by state file
Nov  2 13:50:22 Cobalt NetworkManager[978]: <info> WWAN enabled by radio killswitch; enabled by state file
Nov  2 13:50:22 Cobalt NetworkManager[978]: <info> WiMAX enabled by radio killswitch; enabled by state file
Nov  2 13:50:22 Cobalt NetworkManager[978]: <info> Networking is enabled by state file
Nov  2 13:50:22 Cobalt NetworkManager[978]: <warn> /sys/devices/virtual/net/lo: couldn't determine device driver; ignoring...
Nov  2 13:50:22 Cobalt NetworkManager[978]: <warn> bluez error getting default adapter: Message did not receive a reply (timeout by message bus)
Nov  2 13:50:22 Cobalt kernel: [   28.688167] type=1400 audit(1351882222.452:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1046 comm="apparmor_parser"
Nov  2 13:50:22 Cobalt bluetoothd[1062]: Failed to init network plugin
Nov  2 13:50:22 Cobalt bluetoothd[1118]: Failed to init network plugin
Nov  2 13:50:22 Cobalt bluetoothd[1237]: Failed to init network plugin
ps aux | grep -i network:
root       978  0.0  0.1  23732  4808 ?        Ssl  13:50   0:00 NetworkManager
sudo modprobe -r forcedeth:
FATAL: Module forcedeth not found
BuZZ-dEE
  • 14,533
sudo apt-get remove bcmwl-kernel-source
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install linux-firmware-nonfree
As I found, following these instructions and giving the machine a restart fixes the wireless adapter. DON'T go installing the Broadcom proprietary drivers through System Settings, Additional Drivers, or you'll just reset the whole lot back to the non-working ones!
mrcktz
  • 1,774
SAntiago
Same thing happens to me but I just run the update manager again without attaching my cables or the mobile broadband. The Update Manager tells me there is update available downloaded but not installed, I then click on install and reboot the machine. Everything is working fine. Try that.
Peachy
  • 7,235
  • 40
  • 47
Very similar experience than Adil Elsir.
I did a dist upgrade from 12.04 to 12.10. At the end of the process it mentioned that some errors happened. I had a look but found nothing useful, so rebooted. Then the same symptoms started: VGA mode, no network. Also sudo restart networking crashed the desktop.
So I tried sudo apt-get upgrade, which prompted me that something was wrong and I should try to force install, so I did sudo apt-get upgrade -f, then rebooted a few times. Once again I tried to upgrade and he tells me there is more package that were "kept back". Most notably linux-image-generic (!). apt-cache policy linux-image-generic told me that I was running 3.2 and 3.5 could be installed. So I did sudo apt-get dist-upgrade and that went rather well.
However on reboot I got a kernel panic (not my day). But rebooting again and selecting kernel 3.2 in grub allowed to actually log in in my desktop with normal graphics and networking. Yay !
tl;dr keep upgrading whatever you can via sudo apt-get upgrade -f and sudo apt-get dist-upgrade
PowerKiKi
  • 954
