Start up toward login screen lasts about 40sec on both(12.10 and 12.04). This is good for me.
But after login, there is quite difference. System will start up in:
  • Ubuntu 12.04: 10-13sec
  • Ubuntu 12.10: at least 30sec
I have chromium in start up applications and this is the only non default app there. I also disabled some unneeded apps such as Bluetooth Manager, ... I also have installed preload.
Is there problem on my side or is the new Ubuntu slower in this way?
My PCs info:
Intel® Pentium(R) CPU G840 @ 2.80GHz × 2
GeForce GTS 450/PCIe/SSE2
Memory 3.9 GiB
Ubuntu 12.10 32-bit
madox2
  • 795
For me it varies.
On some PCs the time is the same, on others the time for 12.10 is slightly faster. On a few, the time difference is noticeable (Like 10 to 15 seconds faster). This changes if I update the system. After upgrading 12.10, the changes is more noticeable for more PCs as 12.10 somehow speeds up.
What I would recommend would be to remove preload, Chromium and any other non-default changes you made. Then test both. Just a FYI, preload sometimes does not make the boot part faster. This varies on the hardware/software.
For 40 seconds of time, I would also suggest for you to add your hardware specs here. This could lead to better help.
Luis Alvarado
  • 216,643
Try installing Ubuntu 12.10 64-bit if your processor is 64-bit architecture. Actually I have a Laptop (Asus) with Ubuntu 12.10 64-bit and it runs faster than Ubuntu 12.04 LTS 64-bit.
Aditya
  • 13,616
