I have a HP Pavilion laptop with an AMD Radeon HD 6400M graphic card. When I upgraded from 12.04 to 12.10 all was fine and dandy, until I plugged in my TV via HDMI-cable. After a reboot, Unity stopped working and I was getting all sorts of gpu-related error messages.
Well, I consulted Google and while trying to fix this, I kind of went haywire, adding different repositories to install homebrewed solutions, upgrading and downgrading drivers from AMD:s support page, tinkering with settings and so on. It didn't help.
I finally removed all the mentioned repositories, purged all fglrx files and tried to remove all added drivers, but got some dkpg errors.
The situation right now: Unity doesn't work, but Gnome do. Under 'additional drivers', I have the "Advanced Micro Devices [AMD] nee ATI: Caicos [Radeon HD 6400M/7400M Series]" driver. I've tried both X.org, fglrx and fglrx-updates, but still, no Unity.
I've given up trying to fix this myself, I'd rather wait for a working update.
Is there a way to completely reset the graphic drivers to installation default, or do I have to re-install Ubuntu 12.10?
(and before anyone mentions it, NO, I don't want to use Gnome, I like Unity and want it to work.)
Jorge Castro
  • 73,717
Ok, Let me just say I was just looking for reviews on the 12.10 drivers before I install and I'm on Windows 8, so not sure if this will help:
  • I do remember if you go to your Ati Catalyst Control Center.. and this is how it is in windows but it's probably the same for Linux/Ubuntu -in the top right corner it says Preferences - Click on that button and then the fourth one down is - Restore Factory Defaults...
  • Your best bet is probably just go back to 12.04 when everything was fine- just reinstall the 12.04 one from the Ati website.
This ended up not working for me. There is a better answer at How do I get AMD/Intel Hybrid Graphics drivers to work?
naught101
  • 1,652
It may be the AMD Graphics, perhaps you could use the below to move to Intel Graphics:
edit the /etc/fstab and add the following lines:
tmpfs /dev/shm tmpfs defaults 0 0
none /sys/kernel/debug debugfs defaults 0 0
then edit the /etc/rc.local and add before exit0:
chown $User /sys/kernel/debug/vgaswitcheroo/switch
echo OFF> /sys/kernel/debug/vgaswitcheroo/switch
once you have done that use the attached script & drop it into your /usr/bin folder, and then drop the attached icons into home/$User/.local/share/icons folder
Note: you may want to change the $User in the /home/%User/.local/share/icons element to be the user on your machine. make sure the attached file is executable or it wont work; so either chmod or change permissions by right click.
prior to running the script ensure you have installed gxmessage:
sudo apt-get install gxmessage
To have permanent write permissions to the switch file, add the following line, replacing USERNAME with your username, to /etc/init.d/rc.local:
chown USERNAME /sys/kernel/debug/vgaswitcheroo/switch
then simply run the following command:
switch_between_cards
the switch 1-4 picture attached shows the process and you can see my radeon card is going from off to on to off again
references:
https://help.ubuntu.com/community/HybridGraphics
In addition to solve some dependencies I have add the following to the top of the script:
if [ $EUID != 0 ]; then
    gksudo "$0" "$@"
    exit $?
fi
Note: Thanks to druellan (i have adapted his addition and removed the gnome-session-quit option)
good luck
hope this helps
Here is a link for the switch script:
http://ubuntuforums.org/showthread.php?t=1927317&page=3
