I'm trying to dual boot my Windows 8 machine with Ubuntu 12.04 but I cannot even get to the Live CD under UEFI. I've already set my UEFI boot loader to load from the DVD drive before anything else but it keeps on loading Windows 8 first thing. I've checked that the Ubuntu installer I am using is working by setting the BIOS to legacy boot; under this setting, I can get to the Live CD but it cannot detect Windows 8---something I do not want to happen.
Just for the record, my boot order is as follows:
  1. ATAPI CDROM: HL-DL-ST DVDRAM GT51N
  2. USB CDROM:
  3. USB FDD
  4. USB HDD
  5. HDD: TOSHIBA [SERIAL NUMBER]
  6. Network Boot-IPV4:
  7. Network Boot-IPV6
  8. Windows Boot Manager
Has anyone ran into the same problems as me for UEFI? What am I missing here?
Post-resolution update: In a rather embarassing turn of events, it appears that the Ubuntu installer I am using is not even 32-bit. There is no such thing as UEFI for 32-bit.
Most motherboards have an option to launch a boot manager at boot time, typically by pressing a function key (F8, F10, and F12 are all reasonably common). On many UEFI systems, this boot loader includes separate BIOS (aka legacy) and EFI/UEFI boot options for optical discs. Thus, my first recommendation is to try using this built-in boot manager.
Another option may be to disable your firmware's BIOS/legacy boot option. From your description, it sounds like you've found this option and tried setting it to BIOS/legacy mode, but if the option was set to "auto" before, setting it to "EFI" or "UEFI" might get things working.
You could also try installing rEFInd on a USB flash drive and boot from it. rEFInd should scan your system for EFI-bootable media, including optical discs, and enable you to boot them in EFI mode. The trouble is installing to the flash drive is an extra bother, and you might not have any better luck getting rEFInd to launch than you're having with the Ubuntu disc.
A fourth option is to create a USB-bootable version of the Ubuntu installer and try booting from it.
Rod Smith
  • 45,120
  • 66
  • 108
