I installed windows 7 first and then Ubuntu, booted back into windows and used EasyBCD to use the Windows 7 bootloader for dual booting. So when the system is rebooted Windows bootloader comes up first and once you select Ubuntu then GRUB shows up.
I need to how to make GRUB the default bootloader instead of windows 7's.
Thank you
Simple. Boot-repair.
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
Then run Boot-repair by sudo boot-repair and use "Recommended repair".
GRUB2 will automatically detect windows boot Path.
m4heshd
  • 176
If you are somewhat of a beginner, you should use boot repair.
astex
  • 1,081
