I've got a pluscom pci card plugged into my desktop and although the mac address shows up in network manager, it says "Wireless unavailable".
I'm using Ubuntu 12.10 Gnome Shell Remix...
edgar@edgarQuantal:~$ iwconfig
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
edgar@edgarQuantal:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 6c:f0:49:02:1f:b8
          inet addr:192.168.0.7  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::6ef0:49ff:fe02:1fb8/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1425 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1393 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:995753 (995.7 KB)  TX bytes:134079 (134.0 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:363 errors:0 dropped:0 overruns:0 frame:0
          TX packets:363 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:40828 (40.8 KB)  TX bytes:40828 (40.8 KB)
It looks the same as the problem as here, seems quite complicated: http://ubuntuforums.org/showthread.php?t=1993226
Tried downloading the driver but I get this:
Unpacking firmware-ralink (from .../firmware-ralink_0.36_all.deb) ...
dpkg: error processing /home/edgar/Downloads/firmware-ralink_0.36_all.deb (--install):
trying to overwrite '/lib/firmware/rt2870.bin', which is also in package linux-firmware 1.95"
Zanna
  • 72,312
Luigi
  • 31
An interface should always have a MAC address associated with it. If it says "wireless unavailable" I would expect that you are not seeing or associating with an access point or wireless switch/router.
Does your wireless work from a different OS, a different device, or from your system running from a LiveCD/DVD?
For general troubleshooting, see this help.ubuntu.com page.
See Broadcom 4312 wireless issues and https://askubuntu.com/questions/57554/how-can-i-troubleshoot-my-installation-of-the-latest-broadcom-driver
Also try resetting power (via this answer ) :
Remove all power sources(cables/batteries).
Act like you're powering on the device (press and hold the power button or power cycle several times even though it has no power).
Reconnect all power sources and boot.
The goal of that set is to remove power from wherever the wireless card stores the hardware disabled state and defaults to 'enabled' on the next boot.
Based on the forum thread you mention, you might try this driver: http://packages.debian.org/sid/all/firmware-ralink/download .
belacqua
  • 23,540
