I have an external NTFS hard drive. It automounts with rwx rights for the active user. I am able to create directories, update files, write to existing files, change names of files, etc.
What isn't working is creating new files. Not in newly created directories, nor anywhere else. Under Windows my drive has currently only one user (everyone) with full access.
I also tried using fstab and NTFS-3G to mount the drive with different kind of permissions, but the results are the same: I can't create new files.
Any suggestions on how to solve this?
Bert
Sorry if I wasn't clear v2r
There is another box to tick if you click advanced but that is if you have more than 1 NTFS partition but if you only have 1 NTFS partition it should be ticked as default but look anyway just to make sure otherwise there are only 2 boxes to tick.
1 box is called "Enable write support for external devices" and the other box is called "Enable write support for internal devices" so depending if your NTFS drive is internal or external tick the relevant box.
Sorry I can't give you screenshots not enough rep points yet but I'll replace the url typed at the bottom with a screenshot as soon as I have enough points it will have an example of NTFS Configuration Tool or type NTFS Configuration Tool in Google image search.
Edit: This method worked for me.
Open up Ubuntu Software Centre and type NTFS and install NTFS Configuration Tool (it should be the first one in the list of results). Once installed run NTFS Configuration Tool and tick both boxes and now you should have full access to to your drive.
v2r
  • 9,707
