273
I have an Ubuntu server to which I am connecting using SSH.
I need to upload files from my machine into /var/www/ on the server, the files in /var/www/ are owned by root.
Using PuTTY, after I log in, I have to type sudo su and my password first in order to be able to modify files in /var/www/.
But when I am copying files using WinSCP , I can't create create/modify files in /var/www/, because the user I'm connecting with does not have permissions on files in /var/www/ and I can't say sudo su as I do in case of an ssh session.
Do you know how i could deal with this ?
If I was working on my local machine, I would call gksudo nautilus but in this case I only have terminal access to the machine.
Jorge Castro
  • 73,717
14 Answers14
169
You're right, there is no sudo when working with scp. A workaround is to use scp to upload files to a directory where your user has permissions to create files, then log in via ssh and use sudo to move/copy files to their final destination.
scp -r folder/ user@server.tld:/some/folder/you/dont/need/sudo
ssh user@server.tld
 $ sudo mv /some/folder /some/folder/requiring/perms
# YOU MAY NEED TO CHANGE THE OWNER like:
# sudo chown -R user:user folder
Another solution would be to change permissions/ownership of the directories you uploading the files to, so your non-privileged user is able to write to those directories.
Generally, working in the root account should be an exception, not a rule - the way you phrasing your question makes me think maybe you're abusing it a bit, which in turn leads to problems with permissions - under normal circumstances you don't need super-admin privileges to access your own files.
Technically, you can configure Ubuntu to allow remote login directly as root, but this feature is disabled for a reason, so I would strongly advice you against doing that.
Sergey
  • 44,353
156
Quick way
From server to local machine:
ssh user@server "sudo cat /etc/dir/file" > /home/user/file
From local machine to server:
cat /home/user/file | ssh user@server "sudo tee -a /etc/dir/file"
KWILLIAMS
Anderson Lira
  • 1,661
Another method is to copy using tar + ssh instead of scp:
tar -c -C ./my/local/dir \
  | ssh dimitris@myserver.com "sudo tar -x --no-same-owner -C /var/www"
IBBoard
  • 237
39
You can also use ansible to accomplish this.
Copy to remote host using ansible's copy module:
ansible -i HOST, -b -m copy -a "src=SRC_FILEPATH dest=DEST_FILEPATH" all
Fetch from remote host using ansible's fetch module:
ansible -i HOST, -b -m fetch -a "src=SRC_FILEPATH dest=DEST_FILEPATH flat=yes" all
NOTE:
  • The comma in the -i HOST, syntax is not a typo. It is the way to use ansible without needing an inventory file.
  • -b causes the actions on the server to be done as root. -b expands to --become, and the default --become-user is root, with the default --become-method being sudo.
  • flat=yes copies just the file, doesn't copy whole remote path leading to the file
  • Using wildcards in the file paths isn't supported by these ansible modules.
  • Copying a directory is supported by the copy module, but not by the fetch module.
Specific Invocation for this Question
Here's an example that is specific and fully specified, assuming the directory on your local host containing the files to be distributed is sourcedir, and that the remote target's hostname is hostname:
cd sourcedir && \
ansible \
   --inventory-file hostname, \
   --become \
   --become-method sudo \
   --become-user root \
   --module-name copy \
   --args "src=. dest=/var/www/" \
   all
With the concise invocation being:
cd sourcedir && \
ansible -i hostname, -b -m copy -a "src=. dest=/var/www/" all
P.S., I realize that saying "just install this fabulous tool" is kind of a tone-deaf answer. But I've found ansible to be super useful for administering remote servers, so installing it will surely bring you other benefits beyond deploying files.
27
May be the best way is to use rsync (Cygwin/cwRsync in Windows) over SSH?
For example, to upload files with owner www-data:
rsync -a --rsync-path="sudo -u www-data rsync" path_to_local_data/ login@srv01.example.com:/var/www
In your case, if you need root privileges, command will be like this:
rsync -a --rsync-path="sudo rsync" path_to_local_data/ login@srv01.example.com:/var/www
See: scp to remote server with sudo.
kenorb
  • 10,944
12
When you run sudo su, any files you create will be owned by root, but it is not possible by default to directly log in as root with ssh or scp. It is also not possible to use sudo with scp, so the files are not usable. Fix this by claiming ownership over your files:
Assuming your user name was dimitri, you could use this command.
sudo chown -R dimitri:dimitri /home/dimitri
From then on, as mentioned in other answers, the "Ubuntu" way is to use sudo, and not root logins. It is a useful paradigm, with great security advantages.
If you use the OpenSSH tools instead of PuTTY, you can accomplish this by initiating the scp file transfer on the server with sudo. Make sure you have an sshd daemon running on your local machine. With ssh -R you can give the server a way to contact your machine.
On your machine:
ssh -R 11111:localhost:22 REMOTE_USERNAME@SERVERNAME
In addition to logging you in on the server, this will forward every connection made on the server's port 11111 to your machine's port 22: the port your sshd is listening on.
On the server, start the file transfer like this:
cd /var/www/
sudo scp -P 11111 -r LOCAL_USERNAME@localhost:FOLDERNAME .
bergoid
  • 71
Here's a modified version of Willie Wheeler's answer that transfers the file(s) via tar but also supports passing a password to sudo on the remote host.
(stty -echo; read passwd; stty echo; echo $passwd; tar -cz foo.*) \
  | ssh remote_host "sudo -S bash -c \"tar -C /var/www/ -xz; echo\""
The little bit of extra magic here is the -S option to sudo. From the sudo man page:
-S, --stdin Write the prompt to the standard error and read the password from the standard input instead of using the terminal device. The password must be followed by a newline character.
Now we actually want the output of tar to be piped into ssh and that redirects the stdin of ssh to the stdout of tar, removing any way to pass the password into sudo from the interactive terminal. (We could use sudo's ASKPASS feature on the remote end but that is another story.) We can get the password into sudo though by capturing it in advance and prepending it to the tar output by performing those operations in a subshell and piping the output of the subshell into ssh. This also has the added advantage of not leaving an environment variable containing our password dangling in our interactive shell.
You'll notice I didn't execute 'read' with the -p option to print a prompt. This is because the password prompt from sudo is conveniently passed back to the stderr of our interactive shell via ssh. You might wonder "how is sudo executing given it is running inside ssh to the right of our pipe?" When we execute multiple commands and pipe the output of one into another, the parent shell (the interactive shell in this case) executes each command in the sequence immediately after executing the previous. As each command behind a pipe is executed the parent shell attaches (redirects) the stdout of the left-hand side to the stdin of the right-hand side. Output then becomes input as it passes through processes. We can see this in action by executing the entire command and backgrounding the process group (Ctrl-z) before typing our password, and then viewing the process tree.
$ (stty -echo; read passwd; stty echo; echo $passwd; tar -cz foo.*) | ssh
[sudo] password for bruce:
[1]+  Stopped                 ( stty -echo; read passwd; stty echo; echo
$passwd; tar -cz foo.* ) | ssh remote_host "sudo -S bash -c \"tar -C
$ pstree -lap $$
bash,7168
  ├─bash,7969
  ├─pstree,7972 -lap 7168
  └─ssh,7970 remote_host sudo -S bash -c "tar -C /var/www/ -xz; echo"`
Our interactive shell is PID 7168, our subshell is PID 7969 and our ssh process is PID 7970.
The only drawback is that read will accept input before sudo has time to send back it's prompt. On a fast connection and fast remote host you won't notice this but you might if either is slow. Any delay will not affect the ability to enter the prompt; it just might appear after you have started typing.
Note I simply added a host file entry for "remote_Host" to my local machine for the demo.
Bruce
  • 211
The scp command can't do what you are asking.
The approach I take is to use sudo on the local or remote system (when it's needed to read or writ a file).
Copy remote root access only file to local root access only file
For example, let's say there is a privileged file /etc/pki/private/identity.pem on a remote system and you want to copy it to your local system. The file requires root/sudo access to read or write the file.
To do that, I use this command pattern:
ROOT_ONLY_FILE=/etc/pki/private/identity.pem
ssh host sudo ls -l $ROOT_ONLY_FILE
ssh host sudo cat $ROOT_ONLY_FILE | sudo tee $ROOT_ONLY_FILE > /dev/null
sudo chmod 600 $ROOT_ONLY_FILE
# sudo chown root:grp $ROOT_ONLY_FILE
It's very important to keep the owner, group and read-write modes set properly when copying these privileged files. That is why I start with the ls -l of the remote file.
The chmod and chown commands are intended to make sure the copy of the file has the same permissions as the original file.
Copy remote root access only file to local file
ssh host sudo cat /var/log/messages | cat > /tmp/host.messages
Using sudo cat $file lets you read the file. You can't use scp because scp would not allow access to that privileged file but sudo cat runs on the remote system as root so it works.
Copy local file to remote file that requires special access only
There are times when you want to update a remote file that is owned by tomcat or another user. In this case, you can still use sudo because root is allowed to write to the remote file and doesn't change the files ownership or permission bits when it writes a file that already exists.
The command is:
cat logging.properties | ssh sudo tee /home/tomcat/conf/logging.properties > /dev/null
Copying directories using tar
While the question only asked about files it's important to realize that this approach can also work with directories.
See https://unix.stackexchange.com/a/10028/119816 for more details.
PatS
  • 127
You may use script I've written being inspired by this topic:
touch /tmp/justtest && scpassudo /tmp/justtest remoteuser@ssh.superserver.com:/tmp/
but this requires some crazy stuff (which is btw. automatically done by script)
  1. server which file is being sent to will no longer ask for password while establishing ssh connection to source computer
  2. due to necessarility of lack of sudo prompt on the server, sudo will no longer ask for password on remote machine, for user
Here goes the script:
interface=wlan0
if [[ $# -ge 3 ]]; then interface=$3; fi
thisIP=$(ifconfig | grep $interface -b1 | tail -n1 | egrep -o '[0-9.]{4,}' -m1 | head -n 1)
thisUser=$(whoami)
localFilePath=/tmp/justfortest
destIP=192.168.0.2
destUser=silesia
#dest
#destFolderOnRemoteMachine=/opt/glassfish/glassfish/
#destFolderOnRemoteMachine=/tmp/
if [[ $# -eq 0 ]]; then
echo -e "Send file to remote server to locatoin where root permision is needed.\n\tusage: $0 local_filename [username@](ip|host):(remote_folder/|remote_filename) [optionalInterface=wlan0]"
echo -e "Example: \n\ttouch /tmp/justtest &&\n\t $0 /tmp/justtest remoteuser@ssh.superserver.com:/tmp/ "
exit 1
fi
localFilePath=$1
test -e $localFilePath
destString=$2
usernameAndHost=$(echo $destString | cut -f1 -d':')
if [[ "$usernameAndHost" == *"@"* ]]; then
destUser=$(echo $usernameAndHost | cut -f1 -d'@')
destIP=$(echo $usernameAndHost | cut -f2 -d'@')
else
destIP=$usernameAndHost
destUser=$thisUser
fi
destFolderOnRemoteMachine=$(echo $destString | cut -f2 -d':')
set -e #stop script if there is even single error
echo 'First step: we need to be able to execute scp without any user interaction'
echo 'generating public key on machine, which will receive file'
ssh $destUser@$destIP 'test -e ~/.ssh/id_rsa.pub -a -e ~/.ssh/id_rsa || ssh-keygen -t rsa'
echo 'Done'
echo 'Second step: download public key from remote machine to this machine so this machine allows remote machine (this one receiveing file) to login without asking for password'
key=$(ssh $destUser@$destIP 'cat ~/.ssh/id_rsa.pub')
if ! grep "$key" ~/.ssh/authorized_keys; then
echo $key >> ~/.ssh/authorized_keys
echo 'Added key to authorized hosts'
else
echo "Key already exists in authorized keys"
fi
echo "We will want to execute sudo command remotely, which means turning off asking for password"
echo 'This can be done by this tutorial http://stackoverflow.com/a/10310407/781312'
echo 'This you have to do manually: '
echo -e "execute in new terminal: \n\tssh $destUser:$destIP\nPress enter when ready"
read
echo 'run there sudo visudo'
read
echo 'change '
echo '    %sudo   ALL=(ALL:ALL) ALL'
echo 'to'
echo '    %sudo   ALL=(ALL:ALL) NOPASSWD: ALL'
echo "After this step you will be done."
read
listOfFiles=$(ssh $destUser@$destIP "sudo ls -a")
if [[ "$listOfFiles" != "" ]]; then
echo "Sending by executing command, in fact, receiving, file on remote machine"
echo 'Note that this command (due to " instead of '', see man bash | less -p''quotes'') is filled with values from local machine'
echo -e "Executing \n\t""identy=~/.ssh/id_rsa; sudo scp -i \$identy $(whoami)@$thisIP:$(readlink -f $localFilePath) $destFolderOnRemoteMachine"" \non remote machine"
ssh $destUser@$destIP "identy=~/.ssh/id_rsa; sudo scp -i \$identy $(whoami)@$thisIP:$(readlink -f $localFilePath) $destFolderOnRemoteMachine"
ssh $destUser@$destIP "ls ${destFolderOnRemoteMachine%\\\\n}/$(basename $localFilePath)"
if [[ ! "$?" -eq 0 ]]; then echo "errror in validating"; else echo -e "SUCCESS! Successfully sent\n\t$localFilePath \nto \n\t$destString\nFind more at http://arzoxadi.tk"; fi
else
echo "something went wrong with executing sudo on remote host, failure"
fi
ENDOFSCRIPT
) | sudo tee /usr/bin/scpassudo && chmod +x /usr/bin/scpassudo
test30
  • 517
You can combine ssh, sudo and e.g tar to transfer files between servers without being able to log in as root and not having the permission to access the files with your user. This is slightly fiddly, so I've written a script to help this. You can find the script here: https://github.com/sigmunau/sudoscp
or here:
#! /bin/bash
res=0
from=$1
to=$2
shift
shift
files="$@"
if test -z "$from" -o -z "$to" -o -z "$files"
then
    echo "Usage: $0    (file)*"
    echo "example: $0 server1 server2 /usr/bin/myapp"
    exit 1
fi
read -s -p "Enter Password: " sudopassword
echo ""
temp1=$(mktemp)
temp2=$(mktemp)
(echo "$sudopassword";echo "$sudopassword"|ssh $from sudo -S tar c -P -C / $files 2>$temp1)|ssh $to sudo -S tar x -v -P -C / 2>$temp2
sourceres=${PIPESTATUS[0]}
if [ $? -ne 0 -o $sourceres -ne 0 ]
then
    echo "Failure!" >&2
    echo "$from output:" >&2
    cat $temp1 >&2
    echo "" >&2
    echo "$to output:" >&2
    cat $temp2 >&2
    res=1
fi
rm $temp1 $temp2
exit $res
sigmunda
An older question, I know, but times change and so do some techniques. Just in case someone is still looking for a streamlined way to accomplish this.
Assumptions
  1. Your user on the server is a sudoers.
  2. You are running Windows 10.
  3. The files in /var/www should belong to user:group www-data:www-data
Concept
The concept is to combine remote commands over ssh and scp file transfersers without relying on GUIs such as PuTTy or WinSCP. These commands can be run either from a Command Prompt or PowerShell. There are five main tasks to permorm:
  1. Environment setup
  2. Transfer files to server
  3. Set remote file permissions
  4. Transfer between remote folders
  5. Cleanup
Tasks 3-5 can be performed in a single step. If you plan to do this often, leaving the environment setup will allow you to omit tasks 1 and 5.
Environment Setup
You may or may not already have folder you can use as a temporary repository for the transfer. If not, you can run:
ssh user@server.tld "mkdir ~/wwwtemp"
Depending on your server's settings, you may or may not be prompted for user's password/passphrase to authenticate the ssh session.
Once the session is authenticated, the mkdir ~/wwwtemp command will execute then the ssh session will terminate, and you will be back at your prompt (Command Prompt or PowerShell).
Transfer Files to Server
The next thing to do is to transfer the files from the local Windows machine to the Ubuntu server using scp like so:
scp -R local\path user@server.tld:~/wwwtemp/
Depending on your server's authentication method, you may or not need to enter a password/passphrase.
Permissions and Final Destination of Files
Once the file transfer has completed, you can run a series of commands over ssh like thusly:
ssh -t user@server.tld "sudo chown -R www-data:www-data ~/wwwtemp  && sudo mv -R ~/wwwtemp/* /var/www/ && sudo rmdir ~/wwwtemp"
Again, depending on the authentication method of your server you may or may not be prompted for a password/passphrase. Regardless of your authentication method, sudo will prompt you for user's password. Unless, of course you have disable requirement for password when user runs chown mv and rmdir. See this question for guidance on how to do that.
This step covers tasks 3-5:
  1. sudo chown -R www-data:www-data ~/wwwtemp recursively sets the desired file permissions on the files you just uploaded.
  2. sudo mv -R ~/wwwtemp/* /var/www/ recursively moves the contents of the temporary repository to its final destination.
  3. sudo rmdir ~/wwwtemp removes the temporary repository. It is necessary to use sudo here since we changed the directory owner in task 3.
Of course, && separates each command. The commands will be performed in sequence. If you plan to keep the repository wwwtemp, you can omit the final command in the sequence.
Notes
You can omit && sudo rmdir ~/wwwtemp from the end of the final ssh command string if you would like to continue using the temporary repository in future. Doing so also means that you can omit the first ssh command each time you desire to transfer files to your server in this manner.
  1. In the remote machine, create a folder inside the desired folder, like this:
    cd /var/www
    sudo mkdir my_folder
  2. Change the ownership of my_folder to your own user:
    sudo chown -R replace_with_your_user:replace_with_a_user_group my_folder/
    This will recursively change the ownership inside my_folder.
  3. From your local machine, transfer the file you want to the new created folder:
    scp /path/to/your/file replace_with_your_user@replace_with_the_remote_machine_ip:/var/www/my_folder
  4. When the transfer is done, you may want to move your file to the desired location in the remote machine and delete the created folder. In this case:
    sudo mv my_folder/replace_with_your_file /var/www
    sudo rm -Rf my_folder/
-2
$ scp -i example.pem -r sourcefilr.txt ubuntu@10.12.3.4:/example_folder
Before executing this command we need to give full permissions to example_folder:
$ sudo chmod 777 example_folder
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
