As the Title indicates I have some problem with delicate movement of the mouse in Ubuntu fresh installation.
The jerkiness is shown more at small and slow movements when the mouse will move a 2 millimeters to any random positions every 5 centimeters of movements. My mouse is a Microsoft Sidewinder Gaming mouse.
Is there any driver I can use to fix it or any configuration? This is happening both in Unity or inside games and programs.
Braiam
  • 69,112
Ba7a7chy
  • 549
5 Answers5
10
You may try this to check mouse parameters :
Open a terminal and Run this command:
xinput --list --short
output :
abcd@abcd-abcde:~$ xinput --list --short
Virtual core pointer
↳ SynPS/2 Synaptics TouchPad                id=11   [slave  pointer  (2)]
↳ Logitech USB RECEIVER                     id=12   [slave  pointer  (2)]
for me my pointing devices are a Lgitech usb reciver and synaptic touchpad
To list out device Properties :
xinput --list-props "SynPS/2 Synaptics TouchPad"
check properties like acceleration deceleration and see if they seam allright:
if you need to change any value like suppose this one :
Device Accel Constant Deceleration (267):   2.500000
using this command :
xinput --set-prop "SynPS/2 Synaptics TouchPad" "Device Accel Constant Deceleration" 1.5
You may have to play around with this number a bit to set it exactly as you need.
If you need to set this value automatically every time Ubuntu starts then :
create a .sh file
 #!/bin/sh
change the file to executable :
 chmod +x
and Put this in the start-up applications list.
Vikash Singh
  • 2,383
Looking at the mouse settings via the GUI, I found they were set to lowest possible acceleration, and lowest possible sensitivity. So I changed them using the GUI app and so far it's working just fine (after 5 mins)
Check out Pointing Devices in the software center and use settings there (it has a GUI). My mouse has since calmed down.
My Dell Inspiron One has a touch screen, I disabled it and now my mouse is behaving normally. If your computer has a touch screen try disabling it or adjusting the sensitivity.
In my case it was just the mouse itself malfunctioning. Sometimes it's not in software.
deltaray
  • 235
