No default or UI configuration directive found.
I get this error when I tried to reboot Ubuntu with the DiskOnKey flash drive.
There are possible two causers for this:
Cause 1: The flash drive is formatted with NTFS or FAT32
Solution: Format it using FAT16 (or only FAT).
Cause 2: There is a folder /isolinx and the files /isolinx/isolinux.bin and /isolinx/isolinux.cfg on your flash drive
Solution: Just rename all the above folders and files to syslinux
