UPDATE: Since this question has got many views, I just want to add that from Ubuntu 13.04 onwards, proprietary drivers installed perfectly on my MacBook. Versions of Ubuntu prior to 13.04 will have problems
I recently upgraded to 12.10 and was just checking for proprietary drivers to be installed. I found this in software sources
Additional Drivers
When I enabled Nvidia binary Xorg driver, unity disappears along with the launcher and everything. I just have the wallpaper. I did manage to open the terminal and open software sources and select the nouveau display driver which fixed it.
Question is how to enable NVIDIA binary Xorg driver and have everything working?
Hardware: Apple MacBook Pro 9,1 Mid 2012 15 inch non-retina. NVIDIA GeForce GT650M
EDIT: I tried the solution here. And now, when I boot into Ubuntu, I get a blinking cursor. That's all! No tty1, nothing. help !!
EDIT 2: I inserted the Live USB and re installed Ubuntu without formatting the partition. At least, I didn't lose my files, but all softwares are gone. And the output of
lspci -vnn | grep '\''[030[02]]'
is
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:0fd5] (rev a1) (prog-if 00 [VGA controller])
EDIT 3: So, I was checking the link which Shrinivas gave, namely this one http://www.dedoimedo.com/computers/ubuntu-quetzal-nvidia.html and it doesn't work for me. Specifically, where he says to run the command modprobe nvidia_current, I get the output
FATAL: Error inserting nvidia_current (/lib/modules/3.5.0-22-generic/updates/dkms/nvidia_current.ko): Operation not permitted
So, what's the problem? To reiterate, I'm using Ubuntu on an Apple MacBook Pro Mid 2012 15 inch non retina 8GB RAM with NVIDIA GeForce GT650M
pratnala
  • 749
7 Answers7
Same problem here with new kernel update to 3.5.0-21 You can run the terminal from a F##! up unity by keyboard shortcut ctrl+alt+t Then you can run the command software-center to launch the software center or google-chrome to launch the chrome internet browser (better than anything ^^) Install linux-headers-3.5.0-21-generic from software-center (I'm on x64) download the 310.19 version of the driver on Nvidia's website
Ctrl+F1
login with user + psw
cd Downloads (or whatever path you downloaded your nvidia####.run file)
sudo service lightdm stop
sudo sh nvidia.run (I renamed the nvidia install file to "nvidia.run" when downloading) I think I did say yes afterward to everything in the installation process
sudo reboot
Hope it helps
stephenmyall
  • 9,885
Hadrien
This is my output to your command in the terminal:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF106 [GeForce GTS 450] [10de:0dc4] (rev a1) (prog-if 00 [VGA controller])
Actually it seems that nvidia drivers don't fit in ubuntu 12.10. I installed from PPA
sudo add-apt-repository ppa:xorg-edgers/ppa
sudo apt-get update
sudo apt-get install nvidia-current nvidia-settings
This PPA will install all the missing packages (dkms fakeroot linux-source linux-headers-generic linux-headers 3.5.0-17-generic...). I did it yesterday after several attempts with the proprietary drivers and, for now, it works pretty well. If you do not find other solution, give this one a try. Bye!
devav2
  • 37,290
beppe
Install the linux sources and headers. These are required to build the driver.
sudo apt-get install linux-source linux-headers-3.5.0-17-generic
Then unistall any nvidia drivers you have installed.
sudo apt-get remove nvidia-current
Then reinstall the nvidia driver
Then restart the computer
sudo shutdown -r now
It should now boot up using the nvidia drivers.
Downloading the Drivers directly from NVidia and building it worked for me.
Jason
Please see this:
He gives a detailed explanation for installing proprietary nVidia drivers.
Eliah Kagan
  • 119,640
It seems sleep process is much more complicated in such cases..try hibernate against that.as I found it better option or alternative solution.
see this if you prefer to hibernate
NVIDIA drivers install without a fuss on MacBooks on Ubuntu 13.04 and above.
pratnala
  • 749
