I have recently installed Ubuntu 12.04 and also installed Google Earth. After opening Google earth instead of the maps only appears a black screen (I can see the menus with a lot of options in grey). After waiting a few minutes, I see an error saying that google earth was unable to connect to the image server.
I used to have in the same computer Google Earth on ubuntu 10.10 without any problems. Internet works fine, even I can use the internal browser of google earth. I tried disabling ipv6, deleting ~/.config/google and everything I found in google, but it didn't work. Can anybody help me?
Is the whole screen a black screen or just the right window where the 3d view of the earth appears?
How did you install Google Earth? Did you download the original package and install the libgl package with wget http://librarian.launchpad.net/7037027/libGL.so.1 -O libGL.so.1?
If you are using 10.04, you can install Google Earth from the mediabuntu package, maybe this works. Otherwise, if you use 10.10, you can use this guide. This worked for me in 10.10 after I got crashes and black screens while using the original package. Using the original package was a mistake, because the original package never worked for me.
I also show the following shared library dependencies missing after following Google's installation procedures on Ubuntu 12.04
test@localhost:~$ ldd /opt/google/earth/free/googleearth-bin |grep "not found"
libgoogleearth_free.so => not found
libglobalnew.so => not found
System Details:
uname -a
Linux test 3.2.0-31-generic #50-Ubuntu SMP Fri Sep 7 16:16:45 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
It appears that both 'missing' dependencies are actually installed.
test@localhost:~$ locate libgoogleearth_free.so
/opt/google/earth/free/libgoogleearth_free.so
test@localhost:~$ locate libglobalnew.so
/opt/google/earth/free/libglobalnew.so
This apparent library dependency can be satisfied in Ubuntu 12.04 executing the following:
test@localhost:~$ sudo echo "/opt/google/earth/free/" >> /etc/ld.so.conf.d/google-earth.conf && ldconfig
Unfortunately, Google Earth still exhibits the same symptoms when launched. (i.e. Black rendering area and seemingly unable to connect to the server with grayed menu options.)
It looks like this thread also discusses the issue:
Their solution of uninstalling the 64-bit version and subsequently installing the 32-bit version did not work.
