I have edited my sudoers file to allow my non-root user to run sudo commands without being prompted for a password. In vim, how do I create a function that checks whether this condition is true, if not, prompt the user if they want the script to edit and save the sudoers file to make this condition true?
If condition is true, carry-on with rest of script. If condition is not true, the script silently edits/adds the line: %sudo ALL=(ALL:ALL) NOPASSWD: ALL in the sudoers file, saves and then continues on with the next part of the script.
So I've started writing the function using the code:
... #lines 1-5
passChk() {
passPut="%sudo ALL=(ALL:ALL) NOPASSWD:ALL";
passRd=sudo grep -is "$passPut" --file=/etc/sudoers;
if [ $passRd == $passPut ]; then #if sudoers already contains line from $passPut,
                                 #exit passChk and proceed to pkgFetch.
   pgkFetch;
else
   echo "You will be prompted for user password. Do you want to temporarily disable this?";
   read answer;
fi
if [ $answer !="y" ] || [ $answer !="n" ]; then null
elif [ $answer ="y" ]; then
   $passPut|tee -a > /etc/sudoers
elif [ $answer ="n" ]; then
   pkgFetch;
fi;
clear;
passChk;
I am recieving an error on line 9 if [ $passRd = $passPut ]; then pkgFetch; [: too many arguements. I don't get it. I'm trying to test if directory in $passRd contains string from $passPut. What am I doing wrong?
Braiam
  • 69,112
  1. "The bash cookbook" is an excellent resource, you can get the basics online but this will save your butt when you're pressed for time.
  2. Never use double quotes on things you intend to be bare strings e.g. not subject to bash substitution, so that passput line should be single quoted.
  3. Always double quote variable references in a test construct [], [[ ]], (()), etc. Bad things can happen if you don't, read up on it. The preferred construct is:
[ "${passRd}" = "${passPut}" ]
  1. The semi-colons after the function calls are unnecessary and clutter the code.
  2. man test, there must be spaces between every argument in a test call.
  3. set -x on the CLI or pass -x to #!/bin/bash to assist in debugging, see help set for details.
ppetraki
  • 5,531
This book may be best resource for learning Bash Scripting in Ubuntu.
KK Patel
  • 19,753
