In Hungary, the biggest TV channel is RTL Klub, they has a video archive site. They use Silverlight instead of Flash :( What is annoying, they use the lastest version of Silverlight, about 4.x. But Moonlight doesn't support it yet.
I've been tried in Google Chrome (last dev version), and in Firefox (last stable version), and I've been used the both versions of Moonlight, the lastest stable, and the prerelease.
The player loader is displayed, and loaded, but no player displayed after 30 mins waiting.
If I want to switch to Ubuntu completly, how can I manage to play these videos?
Thanks for your anwsers.
Testvideo here. And this is a working video for me.
Also reported to moonlight developers, here.
Debug info:
Source: http://www.rtlklub.hu/most/player/soda/SodaMediaCenter.Player.Rtl.v3.5.xap
Width: 555px
Height: 490px
Background: #
RuntimeVersion: 4.0.50826.0
Windowless: no
MaxFrameRate: 60
Codecs: ms-codecs
Build configuration: debug, sanity checks
Prereleased Firefox output with WinCodecs installed:
$ firefox http://www.rtlklub.hu/most/17345_hirado_lelki_terror_-_elrabloi_tobbszor_eljatszottak_hogy_ki
Moonlight: 2.99.0.10
Moonlight: Attempting to load libmoonloaderxpi
debug_get_option: GALLIUM_DRIVER = softpipe
couldn't open libtxc_dxtn.so, software DXTn compression/decompression unavailable
Moonlight: no audio capture service available
Moonlight: Installing signal handlers for crash reporting.
Moonlight: Enabling MONO_DEBUG=keep-delegates,reverse-pinvoke-exceptions and MOONLIGHT_ENABLE_CONSOLE=1
windowless mode
Using the ff3 bridge
Moonlight: Plugin AppDomain Creation: OK
Moonlight: URL = http://www.rtlklub.hu/most/17345_hirado_lelki_terror_-_elrabloi_tobbszor_eljatszottak_hogy_ki
Moonlight: URL = http://www.rtlklub.hu/most/player/soda/SodaMediaCenter.Player.Rtl.v3.5.xap
debug_get_bool_option: GALLIUM_NOSSE = FALSE
debug_get_bool_option: GALLIUM_DUMP_FS = FALSE
debug_get_bool_option: SOFTPIPE_DUMP_GS = FALSE
debug_get_bool_option: DRAW_FSE = FALSE
debug_get_bool_option: DRAW_NO_FSE = FALSE
debug_get_bool_option: GALLIUM_DUMP_VS = FALSE
debug_get_bool_option: SP_NO_RAST = FALSE
Using managed xaml parser.
Exception while parsing reader (19:26):
System.Windows.Markup.XamlParseException: Could not convert attribute value '0.375' on element GradientStop.
  at Mono.Xaml.XamlParser.ParseAttributeValue (Mono.Xaml.XamlObjectElement element, Mono.Xaml.XamlPropertySetter property) [0x00000] in <filename unknown>:0
  at Mono.Xaml.XamlParser.ParseAttribute (Mono.Xaml.XamlObjectElement element) [0x00000] in <filename unknown>:0
  at Mono.Xaml.XamlParser.ParseElementAttributes (Mono.Xaml.XamlObjectElement element) [0x00000] in <filename unknown>:0
  at Mono.Xaml.XamlParser.ParseObjectElement () [0x00000] in <filename unknown>:0
  at Mono.Xaml.XamlParser.ParseElement () [0x00000] in <filename unknown>:0
  at Mono.Xaml.XamlParser.ParseReader (System.IO.TextReader stream) [0x00000] in <filename unknown>:0
System.Windows.Markup.XamlParseException: Caught exception: Could not convert attribute value '0.375' on element GradientStop.
  at Mono.Xaml.SL4XamlLoader.HydrateInternal (System.Object value, System.IO.Stream xaml, Boolean createNamescope, Boolean validateTemplates, Boolean import_default_xmlns) [0x00000] in <filename unknown>:0
  at Mono.Xaml.XamlLoader.Hydrate (System.Object value, System.IO.Stream stream) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) Mono.Xaml.XamlLoader:Hydrate (object,System.IO.Stream)
  at System.Windows.Application.LoadComponent (System.Object component, System.Uri resourceLocator) [0x00000] in <filename unknown>:0
  at SkyInteractive.Media.Web.Player.Rtl.MainPage.InitializeComponent () [0x00000] in <filename unknown>:0
  at SkyInteractive.Media.Web.Player.Rtl.MainPage..ctor (IDictionary`2 initParams) [0x00000] in <filename unknown>:0
  at SkyInteractive.Media.Web.Player.Rtl.App.Application_Startup (System.Object sender, System.Windows.StartupEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Application.OnStartup (System.Windows.StartupEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Deployment.CreateApplication () [0x00000] in <filename unknown>:0
  at System.Windows.Deployment.LoadAssemblies () [0x00000] in <filename unknown>:0
  at System.Windows.Deployment.InitializeDeployment (IntPtr plugin, System.String xapPath, System.String culture, System.String uiCulture) [0x00000] in <filename unknown>:0
Moonlight: ErrorEventArgs created with message: 'Caught exception: Could not convert attribute value '0.375' on element GradientStop.'
(firefox-bin:11629): Moonlight-WARNING **: (plugin-class.cpp:609):static void Moonlight::EventListenerProxy::proxy_listener_to_javascript(Moonlight::EventObject*, Moonlight::EventArgs*, void*): runtime check failed: (js_sender != NULL)
not implemented: (ErrorEventArgs.lineNumber) plugin-class.cpp:842
not implemented: (ErrorEventArgs.methodName) plugin-class.cpp:855
windowless mode
Shutting down
Shutting down
NOTE: child process received `Goodbye', closing down
antivirtel
  • 3,685
Although simplistic answer this worked for me, I checked both of your links and they worked (with a rather slow video):
  • I used Chrome 11.0.696.25 (79504) Ubuntu 10.10
  • Installed Moonlight from here http://www.go-mono.com/moonlight/download.aspx (installed 64bit)
  • When I opened the video, it required me some Windows Codecs but Chromium downloaded some and at the end I close the RTL Klub page and reopend it and it worked.
Papiux
  • 619
Could be a codec issue since the video isn't shown but player is loaded. Have you installed ubuntu-restricted-extras package?
papukaija
  • 2,425
