I installed the OpenSSH server and client application on Ubuntu, then installed OpenSSH via preware on the HP Touchpad, along with Xecutah, and Xterm. I enter
ssh root@192.168.2.6
and get this line:
Permission denied (publickey,keyboard-interactive).
However when I type in this via the HP Touchpad I am able to ssh into the remote machine after entering the user's password:
ssh user@192.168.2.2
Any help would be appreciated. Thank You.
david6
  • 14,528
  • 38
  • 46
I suspect that the OpenSSH server doesn't allow root logins. In the ssh configuration file, sshd_config (usually in /etc/ssh/, but I have no idea what OS your tablet is running), there is a line containing the following:
PermitRootLogin no
If that is the case, change the no to yes. Otherwise, look through the config file and any authentication logs you might be able to find.
January
  • 37,208
This is how sshd is running on my TouchPad (from ps -ef |grep sshd):
/opt/sbin/sshd -D -p 22 -o PasswordAuthentication no -o PermitRootLogin without-password
This indicates that you can log in as root once you set up authentication keys. So from the TouchPad, I downloaded my public key (created with ssh-keygen -t dsa) from a Linux box (192.168.0.254) and stored it on the TouchPad in the .ssh directory as the file 'authorized_keys':
root@HPTouchPad:/var/home/root# scp myuser@192.168.0.254:~/.ssh/id_dsa.pub .ssh/authorized_keys
Once that's done, I could ssh into the TouchPad (192.168.0.32) as the root user.
myuser@alinuxbox:~$ ssh root@192.168.0.32
Eric Carvalho
  • 55,453
Shinto
