112
The following command:
$git config --global --list
gives me:
user.name=test user
user.name=gotqn
I want to remove the first name. I referred to this article and have done the following commands but without any result:
git config --global --remove-section user.name='test user'
git config --global --remove-section user.name="test user"
git config --global --remove-section user.name=test user
git config --global --remove-section test user
I am using Ubuntu 12.04 and
git version
gives me
git version 1.7.9.5
Please, help on this, because I want to try to save my project using git, but do not want to exec the command with 'test user' name.
gotqn
  • 2,077
  • 30
  • 38
8 Answers8
118
You can edit the ~/.gitconfig file in your home folder. This is where all --global settings are saved.
BuZZ-dEE
  • 14,533
Marco Ceppi
  • 48,827
106
Super late answer, but hopefully still helpful:
git config --global --unset-all user.name
Then you're free to:
git config --global --add user.name <whatever>
thefourtheye
  • 4,922
  • 26
  • 32
njmason
  • 1,161
10
Or you can just change the user name like this:
git config --global --replace-all user.name "New User Name"
Crusader
  • 210
git config --global -e
This command will open GNU nano editor with what you are expecting.
gobi
  • 161
Last but not least usefull, although it's a marginal case is to use
In my case it cleared the data perfectly and with little to no effort
You can edit your .git/config file present in the local repository repo manually as below:
[core]
        repositoryformatversion = 0
        filemode = true
        bare = false
        logallrefupdates = true
        ignorecase = true
        precomposeunicode = true
[user]
        email = <username>@gmail.com
[remote "origin"]
        url = https://github.com/<username>/<repo_name>.git
        fetch = +refs/heads/*:refs/remotes/origin/*
[credential]
        username = <user_name>
[credential "user"]
[branch "master"]
        remote = origin
        merge = refs/heads/master
"config" 19L, 427C
Now try in terminal:
git push -origin master
git config user.name 'your user name'
git config user.email 'your email name'
you can config for your every company project。And global's user name set your private github name and email.I thought this should be the best way for handle this condition.
muru
  • 207,228
Feng Li
I was having trouble trying to clear out double entries for core.editor... I'd run
git config --unset-all core.editor
then
git config --list
and see no changes.
The answer was to run:
git config --global --unset-all core.editor
