I am having problems with subtitles in my language. They are encoded as Western(ISO-8859-15) and therefore some characters are not displayed correctly. I am tired of replacing manually using gedit and ctrl-h and then saving as UTF-8. How to automate this process?
You can use iconv:
If the file is named chapter1.srt, then run:
iconv -f iso88591 -t utf8 chapter1.srt > outputfile.srt
and it will create the file, although it'll have a different name. If you move them out into another directory, then you can easily pipe them back in.
- 20,726
- 20,906
Another option is
konwert
konwert isolatin1-utf8 inputfile.srt > outputfile.srt
Besides conversion, konwert can also be used as an encoding detector:
konwert any/en-test inputfile.srt
Which is great to get the input file encoding needed for the conversion, since both konwert and iconv requires that as argument. You must however provide a language parameter: en in any/en-test means English
It also has an option for in-place conversion, so you don't have to move and rename files afterwards:
konwert isolatin1-utf8 -O inputfile.srt
- 20,726
Also, since you're dealing with .srt files, you should really check pysrt. It has many features to manipulate subtitles, like shifting and rescaling times.
Installing:
sudo pip install pysrt
Converting to UTF-8 (it auto-detects input file encoding using either chardet or charade)
srt -i --encoding 'utf-8' shift 0s mysubtitle.srt
- 20,726
