I want to use rsnapshot for remote backups of my websites.
It is not clear this line in rsnapshot.conf:
snapshot_root   /.snapshots/
In the documentation, it says snapshots are stored in this directory, but I actually want them to be stored on a remote server and this is specified later with the line
backup local_folder remote_server
so what's snapshot_root then ?
Jorge Castro
  • 73,717
aneuryzm
  • 899
snapshot_root is the root for the paths you specify under backup.
For example:
snapshot_root  /var/backups/me/
backup /home/me/movies/ /media/
backup /home/me/music/  /media/
backup /home/me/drafts/ /documents/
After running rsnapshot hourly, for example, the snapshots would be stored under
/var/backups/me/hourly.0/media
/var/backups/me/hourly.0/documents
The snapshot target must be a local filesystem (although the source can be remote).
I think the simplest option is to put the rsnapshot service on the remote server, and let it copy from your webserver. Using ssh, it would look something like
backup me@example.com:/home/me/movies/ /media/
You would need to have the ssh daemon running on the "example.com" box, and configured so that the user (here "me") can ssh into "example.com" without being asked for a password.
See the rsnapshot HOWTO (section 4.3.8 Backup) for more details.
j-g-faustus
  • 5,678
I had the same issue... and discovered that if I locally mount a folder from the remote system, then rsnapshot will allow me to set the "snapshot_root" configuration parameter to point to it.
This then allows me to store my snapshots and my backup on the same remote server.
eg.
Mount a folder from the remote system
mount 192.168.0.2:/volume1/Backup /mnt/Backup
Set the "snapshot_root" configuration parameter to point the mounted folder
snapshot_root /mnt/Backup/rsnapshot/
Set a rsnapshot backup point to backup a local folder remotely
backup /home/backup-source user@192.168.0.2:/volume1/Backup/backup-target/ rsync_short_args=-trvsz
Note: Although I could have simply designated the mounted remote folder instead as a backup destination, (see below), this would not have enabled me to utilise the Rsync server running on the remote target, (in this case a Synology NAS). I used shared keys to allow rsnapshot to access the remote backup target without a password
backup /home/backup-source /mnt/Backup/backup-target/ rsync_short_args=-trvsz
Rat
