My fresh ubuntu 12.10 install is slow, not something extreme but dragging windows, switching workspaces and things like that are just slow and look horrible. it feels like the fps is dropping in a game. Doing some photoshop work in windows was even a relief! This effect gets worse if I connect my external monitor.
My system is an intel pentium dual core T4500 with 4gb memory and a GeForce 8200M G/integrated/SSE2 graphics chip. Nothing fancy but should be able to run ok. My "experience" in ubuntu is set to standard. (MSI cr500 laptop)
I've installed the nvidia drivers, tried current and experimental and the experimental drivers seem to perform a bit better but overall bad anyway. I set the mode to adaptive in the nvidia-settings tool and it goes to maximum setting directly and doesn't come back.
Using htop I found out that compiz or the X server always use a few percent of my cpu, more than I think it should and the time consumed is 5:18 for compiz, 4:33 for /usr/bin/X and 2:41 for google chrome(about 30 tabs open so not too strange I think.) What can I do to increase the visual performance cause this makes me not want to use ubuntu in public!
Steven Stip
  • 1,920
On my system (13.04) the problem was with the compiz refresh rate, it is automatically set to 50hz, this is not enough, after changing it to 120hz and disabling the auto detection the interface is smooth. You can change the refresh rate in the compizconfig settings manager. The bad thing is that the refresh rate is always set to 50hz after a restart of the system. Seems to be this bug: Incorrect (low/stuttering) refresh rate with NVIDIA driver
I'm inexperienced with nVidia, but you could: 1: Check in CCSM (compiz config settings manager) for the OpenGL, and play around a bit with the configs. (in my case, ati, the sync to vblanc used to produce tearing). CCSM might not be installed by default.
2: You could try the closed or open sourced drivers. This page might help: https://help.ubuntu.com/community/BinaryDriverHowto/Nvidia
Good luck! Cheers.
ubunchu
  • 41
My experience was the same in 12.04 on my desktop (Nvidia Geforce 230) and laptop (Nvidia Geforce 9300M).
Though there has been much worked on Unity performance in the oneiric cycle I would consider low end Nvidia graphics cards to slow, when you are expecting to run a desktop at 60 fps. By "low end" I mean every model with a 4 or lower as the second number from the left in the model number (X4XX or X4X). This applies for the 200 series and below, but even the 400 series and newer low end cards are mostly rebranded versions of older stripped down designs.
Intel's IGP in Sandy Bridge and Ivy Bridge CPUs on the other side run fine and deliver a 60 fps like performance on the desktop compared to the 24 fps (fluid, but rather sluggish) like performance of Nvidia's low end cards. This may just be a driver issue but it's a long standing one like KMS support for the binary driver. Probably even caused by that.
LiveWireBT
  • 29,597
I've found that disabling a number of options under the compizconfig settings manager makes it quite a bit faster:
OpenGL>Untick Framebuffer object and Vertex buffer object (and possibly sync to VBlank) and change texture filter to fast.
Ubuntu Unity Plugin>Experimental>Change Dash Blur to No Blur
Animations>Either reduce the time of or change various animations (particularly the minimize ones), or disable them altogether.
This should make Unity much more usable. Xubuntu/XFCE or other environments are also an option.
You could also try using a different driver (e.g. nvidia-experimental-304), or one from the NVIDIA page:
http://www.nvidia.com/object/unix.html
Be sure to run nvidia-xconfig after installing one though, and add nomodeset to grub parameters.
Joshun
  • 141
