Is there a way to have the number of workspaces automatically increase and decrease intelligently?
For example: I set a minimum of 2 workspaces, but if I have windows on those workspaces, a 3rd workspace is automatically created. If I close out the windows on workspace 2, then workspace 3 is removed.
Bruno Pereira
  • 74,715
Sepero
  • 4,627
I am guessing you are using Unity. This idea is a feature in the Gnome-3 desktop environment see the right column on the image below - workspaces are added and removed as necessary. In this case there are two, but if the user puts something in the second workspace, a third one is created.). enter image description here.
To install the gnome-shell, use these commands here:
Then, log-out and before you log back in, change your desktop by clicking on the Ubuntu icon near your login name. Here are more detailed instructions.
philshem
  • 2,103
If you don't mind puzzling pieces together yourself, you can use wmctrland a bit of bash scripting.
  • count current workspaces: wmctrl -d | wc -l
  • change number of workspaces: wmctrl -n 4
  • check which workspaces currently have windows: wmctrl -l
  • move a window to another workspace: wmctrl -ir 0x0120017b -t 3
Tested on xfce and unity. On unity, however, wmctrl seems to be unable to move xmessage windows.
mk.pmb
