I've already went through all possible advices and still cannot start my Atheros AR9285 wireless card.
I have a laptop Toshiba Portege Z830 where the WiFi already worked under Windows 7. But after migration on Ubuntu 12.10. I'm not able get it work.
This is what I see on command lshw
*-network UNCLAIMED
       description: Network controller
       product: AR9285 Wireless Network Adapter (PCI-Express)
       vendor: Atheros Communications Inc.
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:c0500000-c050ffff
This is what I see on command rfkill list
0: Toshiba Bluetooth: Bluetooth
    Soft blocked: yes
    Hard blocked: no
1: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
Any idea?
Peachy
  • 7,235
  • 40
  • 47
You can use this command:
sudo modprobe ath9k
to enable the device.
Seth
  • 59,332
BigSack
  • 2,713
You can start with
lsmod |grep mac80211
which gives you the driver name currently working with your wireless device. AR9285 should be using ath9k by default. But in your case it seems your wireless adapter is not enabled at all. You can try this way
echo "options ath9k nohwcrypt=1" | sudo tee /etc/modprobe.d/ath9k.conf
It's reported the above workaround solves the wireless connection problem on certain Atheros AR928x platform.
funicorn
  • 4,306
  • 17
