196
Every so often I'll bash out a bash script and it strikes me there are a few ways of setting a variable:
key=value
env key=value
export key=value
When you're inside a script or a single command (for instance, I'll often chain a variable with a Wine launcher to set the right Wine prefix) these seem to be completely interchangeable but surely that can't be the case.
What's the difference between these three methods and can you give me an example of when I would specifically want to use each one?
Definitely related to What is the difference between `VAR=...` and `export VAR=...`? but I want to know how env fits into this too, and some examples showing the benefits of each would be nice too :)
Oli
  • 299,380
Let us consider a specific example. The grep command uses an environment variable called GREP_OPTIONS to set default options.
Now. Given that the file test.txt contains the following lines:
line one
line two
running the command grep one test.txt will return
line one
If you run grep with the -v option, it will return the non-matching lines, so the output will be
line two
We will now try to set the option with an environmental variable.
  1. Environment variables set without export will not be inherited in the environment of the commands you are calling.
    GREP_OPTIONS='-v'
    grep one test.txt
    The result:
    line one
    Obviously, the option -v did not get passed to grep.
    You want to use this form when you are setting a variable only for the shell to use, for example in for i in * ; do you do not want to export $i.
  2. However, the variable is passed on to the environment of that particular command line, so you can do
    GREP_OPTIONS='-v' grep one test.txt
    which will return the expected
    line two
    You use this form to temporarily change the environment of this particular instance of the program launched.
  3. Exporting a variable causes the variable to be inherited:
    export GREP_OPTIONS='-v'
    grep one test.txt
    returns now
    line two
    This is the most common way of setting variables for use of subsequently started processes in a shell
  4. This was all done in bash. export is a bash builtin; VAR=whatever is bash syntax. env, on another hand, is a program in itself. When env is called, following things happen:
    1. The command env gets executed as a new process
    2. env modifies the environment, and
    3. calls the command that was provided as an argument. The env process is replaced by the command process.
    Example:
    env GREP_OPTIONS='-v' grep one test.txt
    This command will launch two new processes: (i) env and (ii) grep (actually, the second process will replace the first one). From the point of view of the grep process, the result is exactly the same as running
    However, you can use this idiom if you are outside of bash or don't want to launch another shell (for example, when you are using the exec() family of functions rather than the system() call).
Additional note on #!/usr/bin/env
This is also why the idiom #!/usr/bin/env interpreter is used rather than #!/usr/bin/interpreter. env does not require a full path to a program, because it uses the execvp() function which searches through the PATH variable just like a shell does, and then replaces itself by the command run. Thus, it can be used to find out where an interpreter (like perl or python) "sits" on the path.
It also means that by modifying the current path you can influence which python variant will be called. This makes the following possible:
echo -e '#!/usr/bin/bash\n\necho I am an evil interpreter!' > python
chmod a+x ./python
export PATH=.
python
instead of running Python, will result in
Pablo Bianchi
  • 17,371
January
  • 37,208
