I have Docky installed on Ubuntu 10.10 64bit and noticed after a recent upgrade my 'Helpers' are no longer available. After some research I found that Dockmanager is no longer installed either.
I am unable to install it via the Software centre or via terminal using apt-get, the following error is returned;
mark@Sonata:~$ sudo apt-get install dockmanager
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  dockmanager
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B/94.4kB of archives.
After this operation, 430kB of additional disk space will be used.
(Reading database ... 162015 files and directories currently installed.)
Unpacking dockmanager (from .../dockmanager_0.1.0~bzr83-0ubuntu1~10.10~dockers1_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/dockmanager_0.1.0~bzr83-0ubuntu1~10.10~dockers1_amd64.deb (--unpack):
 trying to overwrite '/usr/share/dockmanager/data/skype_invisible.svg', which is also in package faenza-icon-theme 0.8
dpkg-deb: subprocess paste killed by signal (Broken pipe)
mark@Sonata:~$
Can anyone advise on how to fix this?
Braiam
  • 69,112
Mark Rooney
  • 6,329
What's happened is that when you updated, it tried to install an update of the dockmanager, but a theme package you installed previously has done naughty things and replaced one of the dockmanager's files.
To fix you need to do the following:
sudo apt-get purge faenza-icon-theme
Then try and reinstall your dockmanager, you also need to report to the maintainer of faenza-icon-theme that he's made a broken package and he should fix it as soon as possible. Basically he needs to make it so that it doesn't replace files from other packages.
dv3500ea
  • 37,734
The easiest way to do this is:
sudo apt-get remove dockmanager
sudo apt-get install dockmanager faenza-icon-theme
amc
  • 7,292
