I would like to remotely reboot my Ubuntu 12.04 LTS server via ssh. I do sudo reboot and I loose connection and the server connection does not reappear. It does not ping.
When I go the the physical computer with a screen attached I see a black screen and hear that the server is still on. I do a hard power off (press power on button for a few seconds) and the server halts. After I press power on the server boots with no problem.
As far as I remember the remote reboot has previously worked on that server.
I wonder if sudo reboot & will help? I suppose I could also try sudo shutdown -r and see if that does any difference.
I have listed an excerpt of /etc/log/syslog below. The last thing it records is the stopping of the logging.
Oct 24 10:14:49 servername kernel: [1354427.594709] init: cron main process (1060) killed by TERM signal
Oct 24 10:14:49 servername kernel: [1354427.594908] init: irqbalance main process (1080) killed by TERM signal
Oct 24 10:14:49 servername kernel: [1354427.595299] init: tty1 main process (1424) killed by TERM signal
Oct 24 10:14:49 servername kernel: [1354427.637747] init: plymouth-upstart-bridge main process (20873) terminated with status 1
Oct 24 10:14:49 servername kernel: Kernel logging (proc) stopped.
Oct 24 10:14:49 servername rsyslogd: [origin software="rsyslogd" swVersion="5.8.6" x-pid="876" x-info="http://www.rsyslog.com"] exiting on signal 15.
Oct 24 10:25:34 servername kernel: imklog 5.8.6, log source = /proc/kmsg started.
Oct 24 10:25:34 servername rsyslogd: [origin software="rsyslogd" swVersion="5.8.6" x-pid="862" x-info="http://www.rsyslog.com"] start
NorTicUs
  • 2,402
  • 20
  • 34
Others have had the same problem: Why can't I restart/shutdown?
Colin Watson suggests trying different parameters for reboot= in grub.
You can also try sudo init6
For more evaluation, you should update the dmesg and syslog outputs , when the server restart.
djlynux
