I tried to upgrade from 12.04 -> 12.10. The install seemed to go well but upon reboot, I get the grub recovery console.
I tried to reinstall using the boot-repair Boot Repair
which usually works a treat. However this time it says it is scanning my HDD and never recovers.
When I try to reinstall grub from the liveDVD using the old
    grub-install <dir> <dev> --recheck --debug &> gruboutput.txt
I get this
Pastebin link
I think it should be installing to dev/mapper/isw_gbaaebhfe_Volume0 even when I made --> dev/mapper/isw_gbaaebhfe_Volume3
Any help would be appreciated
Caustic
  • 749
Create Boot-Repair-Disk would be better option. You can download it here.
KK Patel
  • 19,753
IF you fail to see the Grub:- Insert a Ubuntu 12.10 Live-CD/DVD and run the following commands:
$sudo mount /dev/sdXY /mnt # XY is the drive, eg. sda or sda1
$sudo chroot /mnt
$sudo grub-install /dev/sdX #X is drive number
$sudo update-grub # Note that you just need to enter the 'drive' identifier here, not the partition!
Reboot and take out the LiveDVD. Lemme know if it doesn't work as intended.
TomKat
  • 3,878
you can also have ultimate boot cd on hand run super grub it will allow you to boot the os then run sudo update-grub from the os
