I am trying to upgrade a Dell inspiron 1501 from Windows Vista to Ubuntu. I downloaded the appropriate .ISO file from the Ubuntu site, and used Universal_USB-Installer to create a bootable USB. However, when I run Wubi.exe and take the Help Me To Boot From CD option, I get the following:
10-22 23:25 DEBUG  TaskList: ### Finished check_iso
10-22 23:25 DEBUG  TaskList: ## Finished use_cd
10-22 23:25 DEBUG  TaskList: ## Running extract_kernel...
10-22 23:25 ERROR  TaskList: Could not retrieve the required installation files
Traceback (most recent call last):
  File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__
  File "\lib\wubi\backends\common\backend.py", line 618, in extract_kernel
Exception: Could not retrieve the required installation files
10-22 23:25 DEBUG  TaskList: # Cancelling tasklist
10-22 23:25 ERROR  root: Could not retrieve the required installation files
  File "\lib\wubi\application.py", line 58, in run
  File "\lib\wubi\application.py", line 130, in select_task
  File "\lib\wubi\application.py", line 205, in run_cd_menu
  File "\lib\wubi\application.py", line 122, in select_task
  File "\lib\wubi\application.py", line 228, in run_cd_boot
10-22 23:25 DEBUG  TaskList: # Finished tasklist
Can you help please?
Thanks, Willie
Mark Paskal
  • 2,890
you can try installing dual boot with windows if it will be suggested in install option . Also watch this manual https://www.youtube.com/watch?v=m5Jxfj6tu_U
