I installed texlive 2012 on ubuntu 12.04 LTS 64 bit machine following the instructions given in the following web
How do I install the latest TeX Live 2012?
After, a successful installation( I think), I got the following error when I do a pdflatex to compile a give tex file
This is pdfTeX, Version 3.1415926-2.4-1.40.13 (TeX Live 2012/Debian)
restricted \write18 enabled.
entering extended mode
(./user_guide.tex
LaTeX2e <2011/06/27>
Babel and hyphenation patterns for english, dumylang, nohyphenation, lo aded.
(/usr/share/texlive/texmf-dist/tex/latex/base/article.cls
Document Class: article 2007/10/19 v1.4h Standard LaTeX document class
(/usr/share/texlive/texmf-dist/tex/latex/base/size12.clo))
! LaTeX Error: File `html.sty' not found.
Type X to quit or to proceed, or enter new name. (Default extension: sty)
so would you help me in getting a solution?
Thank you in advance
GGS
  • 71
I had the same problem and found more answers then questions, so I will give an answer. install:
sudo apt-get install latex2html
then it should work :) (it did on my system)
Luis Alvarado
  • 216,643
user146020
  • 61
