I installed a couple of days ago Ubuntu 12.10 (64 bit).
I today tried ripping a CD in the MP3 format.
However, whenever I try to rip, it says it is missing an extra multimedia plugin "Gstreamer extra plug-ins (i386)".
I then try to install the :i386 version of the gstreamer-ugly plugins, but then I get the same problem but with the id3-demuxer (or something similar)
The Terminal output I get from both problems (but replace the "MPEG-1 Layer 3 (MP3) encoder" with the "ID3-demuxer" name) is:
james@clefairy:~$ rhythmbox
(rhythmbox:24122): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
Rhythmbox-Message: Missing plugin: gstreamer|0.10|rhythmbox|MPEG-1 Layer 3 (MP3) encoder|encoder-audio/mpeg, mpegversion=(int)1, layer=(int)3
/usr/lib/python2.7/dist-packages/gobject/constants.py:24: Warning: g_boxed_type_register_static: assertion `g_type_from_name (name) == 0' failed import gobject._gobject
It doesn't help that each time I have to install/remove the entire Gstreamer-ugly collection each time - I can't find that specific file.
The CD plays fine, it's the ripping plugin that doesn't seem to work.
I didn't have this problem previously on 12.04 (64 bit).
Eliah Kagan
  • 119,640
jfy133
  • 368
5 Answers5
Have a look at mc4man's post at http://ubuntuforums.org/showthread.php?t=2080739. Looks like we need to use a custom setting. Worked for me.
Paul B
  • 36
Try installing Synaptic and then install gstreamer0.10-plugins-ugly-multiverse If it still doesnt work i would recommend installing LAME (mp3 encoding front-end)
I suggest using Synaptic, simply because it tends to do better at installing technical items
Nemcruncher95
  • 688
  • 25
Open synaptic, install libmp3lame0 then reboot. You should now be able to rip to mp3 after starting Rhythmbox
James
  • 46
Dunno if you're still having this issue but I've used dagrab for grabbing tracks and lame for mp3 encoding. I made a rip-script years ago that I recently re-wrote as I suddenly needed to rip loads of CDs.. It runs fine on my ubuntu 12.04 64-bit. I've not added any uninstall menu-option yet and the PROXY settings don't work with the cddget (perl) I use nowadays BUT otherwise.. it seems to work fine https://github.com/OlaAronsson/nenRip
After getting the missing extra multimedia plugin "Gstreamer extra plug-ins (i386)" pop-up and a dependency error after accepting recommended install of gstreamer1.0-plugins-ugly (i386) the problem went away once I cleared the user configs by removing files under ~/.local/share/gstreamer-1.0/presets
ref: http://ubuntuforums.org/showthread.php?t=2233131
