Possible Duplicate:
How to bypass/remove/disable the untrusted package authentication
When i try to install softwares from software centre i get an error message as follows :
Requires installation of untrusted packages
in details the following is mentioned:
libcddb2 libdvbpsi7 libebml3 libiso9660-8 libmatroska5 libresid-builder0c2a libsdl-image1.2 libsidplay2 libtar0 libupnp3 libva-x11-1 libvcdinfo0 libxcb-composite0 libxcb-keysyms1 libxcb-randr0 libxcb-xv0
Whether I click on OK or Repair either ways the window closes and I cannot download & install the software.
Check out this article. http://www.liberiangeek.net/2010/10/fix-requires-installation-untrusted-packages-error-ubuntu-10-10-maverick-meerkat/
Even if they are talking about version 10.10 i believe the solution they provide will help you. The key is to use the underlined number and make sure you update your package repository.
Mariyan
  • 231
